[Z06] low oil level
Old Jan 22, 2007 | 12:02 PM
lssix's Avatar
lssix
5th Gear
Default low oil level
new guy. just bought my 1st vette.01 z06 18,000 mi.
i've put 400 mi. on it and this wkend low oil level came on. stopped and checked oil it was fine.
anybody had this happen to them? thanks for any input.
Old Jan 22, 2007 | 12:56 PM
JayZ06's Avatar
JayZ06
I also have an '01 Z. I usually have to add about half to a whole quart of oil in between oil changes. I don't think that it is a huge problem, I don't have any leaks or anything, just seem to burn a little oil in between changes
Old Jan 22, 2007 | 01:06 PM
Dre01SS's Avatar
Dre01SS
I've only had the light come up on mine once, shortly after 3000 miles, but the car did endure lots of high-rpm driving (mountain drives, etc)... But what he said is right, if the light comes on, check the oil level, and add .5-1qt as needed.
And enjoy the Z!
Old Jan 22, 2007 | 02:34 PM
TEXHAWK0's Avatar
TEXHAWK0
If the oil level is OK as you said, then the first suspect would be a faulty oil level transmitter.
Old Jan 22, 2007 | 02:35 PM
BUBBAS 01Z06's Avatar
BUBBAS 01Z06
Tis' normal for an 01
Old Jan 22, 2007 | 05:28 PM
Brian@FI Performance's Avatar
0Brian@FI Performance
Former Vendor
From: FI Performance : Norwalk Connecticut www.FIPERFORMANCE.com
Welcome to the 01 Burner crew!!! I go through about 1 qt every 800 miles and don't mind dumping a qt. of fresh synthetic every now and then.
Old Jan 22, 2007 | 05:43 PM
verskel's Avatar
verskel
How 'sensitive' is the oil sensor ?
Does it trip automatically if it's down 1/2 a quart or more ?
So far I haven't owned mine long enough to comment on oil consumption.
Old Jan 22, 2007 | 11:13 PM
silver_z06's Avatar
silver_z06
this happens to me at times too
Old Jan 23, 2007 | 05:21 AM
lssix's Avatar
lssix
5th Gear
Default low oil level indicator
when i stopped and checked oil it was full. when i started the car the message was gone and didn't come back on while driving home.
Old Jan 23, 2007 | 10:07 AM
BlackZ06's Avatar
BlackZ06
Sometimes if you are parked on a hill you will see the message as the oil in the pan has drained away from the sensor enough to trigger the message.
Old Jan 23, 2007 | 02:25 PM
azmusclecar's Avatar
azmusclecar
Old Jan 23, 2007 | 02:37 PM
O2Thief's Avatar
O2Thief
I use to have the same problem with my 01, 1/2 quart here & there. I changed to a Fast 90/90 and noticed LS6 intake was slightly coated with oil on the inside. I went ahead and purchased a oil catch can and prepared for installation per recommedation from others on the board. Prior to installation I noticed the crappy PCV setup. I've never had any vehicles with a PCV valve mounted in a horizontal position prior to the vette. I replaced the pcv valve with a new unit (old unit was leaking) and setup the PCV valve vertically. To this date (it's been 6 months), I've not burned any oil nor installed the catch can. This also includes 35 passes at the track.
Old Jan 23, 2007 | 02:41 PM
JiminVirginia's Avatar
JiminVirginia
Originally Posted by azmusclecar
Happened to me and several other guys I know.
To low oil level
