Opening Trunk Lid, Convertible
Old Jan 30, 2007 | 07:53 PM
dndrsn's Avatar
dndrsn
OpenEZ™ Trunk Lift
Old Jan 30, 2007 | 08:28 PM
tb7120's Avatar
tb7120
Originally Posted by VET IT B
Adjust the springs, lube all moving parts and clean and lube the weather strips. Do these and problem solved. Mark
I found that putting some lubricant on the weatherstrip helped.
Old Jan 30, 2007 | 08:32 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Originally Posted by 02redrider
Had the same problem. A little WD-40 in the latch mechanism did the trick.
same here...WD40 did the trick for my '04
Old Jan 30, 2007 | 09:49 PM
Optimus_C5's Avatar
Optimus_C5
From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
Originally Posted by MTurnbo
Open the lid with one of the doors open and then close the door. The inside pressure created will pop the lid up higher. But yes, it's pretty normal.
exactly what I do with mine.
Old Jan 30, 2007 | 09:58 PM
80vetla's Avatar
80vetla
got the same problem with 99 vert. posted bout 3 weeks ago and honestly none of the tricks helped much.but i can still grab it open at the corner. was next to a coupe the other day and thiers popped open bout inch and half
Old Jan 30, 2007 | 11:47 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Originally Posted by Frozenfire
I don't think the deck lid was engineered that way, but on my car you can yet your fingers under the right side easier than the left, so that's the side I pry it from. When it's very cold out the deck hardly pops up at all. Then I have to pry the right edge with a key. Shutting the door will also pop it.
I complained about this as a warranty repair and at the time knew it was worse in the colder winter months and was sure the dealer would have just replaced the trunk shocks but they had the ***** to tell me "they all do that" and declared this "normal operation?" Add this to the stack of non acceptable "normal operations" on the GM flagship that we dropped $54K on?
Old Jan 30, 2007 | 11:52 PM
Ol'55's Avatar
Ol'55
Originally Posted by oldschoolvette
I dont think this is normal. my 98 pops up about an inch or so. I know it must be ok because the wife uses the car and doesnt have an issue with it. I think it can be made better, I wouldnt live with it.
I believe you don't experience this problem in it's entirety because of the climate there in Florida. Just another great reason for moving there, right guys?
Old Jan 30, 2007 | 11:54 PM
Ol'55's Avatar
Ol'55
Originally Posted by UncleFodder
My lid gave me a good 3/4" when I first bought it. Several months went by and it turned into fingernail clearance. Some WD-40 applied carefully to all the moving parts gave me 1".
Hmmm. That sounds too easy, but I'll try it. The oiling of the center console surprised the hell out of me!
Old Jan 31, 2007 | 08:53 AM
bonnell's Avatar
bonnell
I do it this way every time.
Old Jan 31, 2007 | 10:07 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Enough BAND-AID attempts to fix this issue!!!!!!
There is a Forum Vendor (Vettemods.com) that for a looooong time offered a resolution to this matter, and few took advantage (I was one that did).
It is called the OpenEz Trunk Lift.
It replaces the OEM trunk latch,
It is powered, thus the trunk is "pushed up" by a motorized part when the trunk is activated by the FOB or the dash button.
Even the most ill prepared CF member can install it (needs a few torq screwdrivers and a couple of sockets and the ability to splice three wires).
I can attest that this works.
Cost a $ or two, but worth it
Old Jan 31, 2007 | 10:15 AM
Boeingman's Avatar
Boeingman
Try raising the rubber stops a tiny bit after lubing all the above mentioned parts.
Old Jan 31, 2007 | 10:40 AM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
A Window Valet may help here - it allows you to control the windows (up and down) via the FOB buttons. t seems to be one of the vendors had made a kit to add more spring force to the trunk springs too....
Old Jan 31, 2007 | 11:02 AM
  #33
dndrsn's Avatar
dndrsn
déjà vu
OpenEZ™ Trunk Lift
Old Jan 31, 2007 | 11:44 AM
  #34
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
Originally Posted by dndrsn
Missed your post above
There have been a lot of posts re this matter, and all provide band-aid solutions, while not addressing the cause and fix
Old Jan 31, 2007 | 12:25 PM
  #35
dndrsn's Avatar
dndrsn
It's definitely a sure fix but too pricey for some. I tried to find a post that explained an adjustment to the spring but couldn't find it. If you have a vert with the top down shutting the door won't work. I guess that's a duh.
Old Jan 31, 2007 | 01:52 PM
  #36
cjs27410's Avatar
cjs27410
http://forums.corvetteforum.com/show...ght=vert+trunk
Check post #'s 23 & 31 --- This worked for me also.
Old Jan 31, 2007 | 02:56 PM
  #37
chai1836's Avatar
chai1836
I too have used the WD-40 trick on mine and it works perfetly now. It did take more than one application over two or three days. I guess it needed time to coat everything.
Old Feb 1, 2007 | 02:49 PM
  #38
vettemods.com's Avatar
vettemods.com
Former Sponsor
St. Jude Donor '06
Thanks guys, yes our product addresses this issue. I to was fed up with the constant attention this required and after some trial and error came up with this product. It basically lifts the lid after the factory mechanism releases.
We are currently out of stock while I wait for some parts, but I should have them in soon so check back!
Take care,
Rick
VOZtech
Old Feb 1, 2007 | 03:02 PM
  #39
cjs27410's Avatar
cjs27410
These 2 posts address the issue without an add on modification and expense.
I have put up with the trunk lid not opening without extra help (slamming the door) for 6 years. Today, I decided to take the trunk compartment apart and lubricate the spring to see if it would help. It didn't work. So, I loosened the 2 bolts that hold the spring mechanism in place and moved it around and closed the trunk until I found the sweet spot then I tightened the bolts. For my vert the sweet spot was to move the spring mechanism to the far left (left if you are facing the trunk) and center of the bolt holes. It now works great, every time! I don't know if this will help other folks but, I wanted to share my good fortune.
OK......I just got back from visiting with my "local vette expert" and............ ............it took him literally 2 seconds to fix my problem!
I've spent over a year trying to make adjustments, change parts, and research solutions, not to mention coming up with alternative ways of getting that f'n thing to open!
As I previously posted, my problem was that the catch on the deck lid was not centered on the locking mechanism. Well, I explained the problem and, get this; he simply pushed on the entire locking mechanism to bend the frame just enough to realign the lock with the catch.
Now it pops open like new and I'll never doubt him again! Now its on to my next fix! I hope this helps anyone that has the same problem that I "had".
