Opening Trunk Lid, Convertible
Old Jan 29, 2007 | 10:12 AM
427435's Avatar
427435
Default Opening Trunk Lid, Convertible
Took our "new" 2003 AE out for a drive yesterday. One issue I've noted is opening the trunk lid. The latch releases OK but the lid doesn't "pop up" far enough to get your fingers under the lid to fully open it. You have to try and pry it up with your finger nails before you can get your hand under it.
Is that normal???
Old Jan 29, 2007 | 10:18 AM
87SAM's Avatar
87SAM
Pretty much. Many have had success by lubing all the mechanisms.
Old Jan 29, 2007 | 10:34 AM
MTurnbo's Avatar
MTurnbo
Open the lid with one of the doors open and then close the door. The inside pressure created will pop the lid up higher. But yes, it's pretty normal.
Old Jan 29, 2007 | 10:40 AM
87SAM's Avatar
87SAM
If that doesn’t work the first couple of times, you may have to put the top up! Sorry, even the wife mentioned I was a smart a** this morning.
Old Jan 29, 2007 | 10:45 AM
Frozenfire's Avatar
Frozenfire
I don't think the deck lid was engineered that way, but on my car you can yet your fingers under the right side easier than the left, so that's the side I pry it from. When it's very cold out the deck hardly pops up at all. Then I have to pry the right edge with a key. Shutting the door will also pop it.
Old Jan 29, 2007 | 10:51 AM
Bill Vett's Avatar
Bill Vett
You can lube the lock and also adjust the two rubber stops . 1/4 turn out it may help spring the lid up a little higher so you can get your fingers under to lift the lid.
Old Jan 29, 2007 | 11:05 AM
427435's Avatar
427435
Thanks everyone. I'll remember the "closing the door" trick and look at adjusting the down stops. The thought of adding a small spring somewhere has also come to mind.
Old Jan 29, 2007 | 12:40 PM
oldschoolvette's Avatar
oldschoolvette
I dont think this is normal. my 98 pops up about an inch or so. I know it must be ok because the wife uses the car and doesnt have an issue with it. I think it can be made better, I wouldnt live with it.
Old Jan 29, 2007 | 01:28 PM
GrayC5's Avatar
GrayC5
Check the latch spring:
1998-2003 Convertible: Trunk Door on Convertible Won't Open All The Way
Old Jan 29, 2007 | 03:07 PM
UncleFodder's Avatar
UncleFodder
My lid gave me a good 3/4" when I first bought it. Several months went by and it turned into fingernail clearance. Some WD-40 applied carefully to all the moving parts gave me 1".
Old Jan 29, 2007 | 09:44 PM
oldschoolvette
Old Jan 29, 2007 | 09:51 PM
Jet-Jock's Avatar
Jet-Jock
Old Jan 29, 2007 | 09:53 PM
RFS-Z06's Avatar
RFS-Z06
Old Jan 29, 2007 | 10:00 PM
DavzC5's Avatar
DavzC5
From: Houston, TX www.djmotorsportaccessories.com Specializing in C5 & C6 Accessories. DJ Motorsport Accessories.
St. Jude Donor '08-'09
with the WD40. I have to spray it about every few month and that keeps her up.
Forgot to say; on my wifes car.
Old Jan 29, 2007 | 10:04 PM
redrider's Avatar
redrider
Had the same problem. A little WD-40 in the latch mechanism did the trick.
Old Jan 29, 2007 | 10:14 PM
Rupert's Avatar
Rupert
It might also be the cold. Mine normally pops up about an inch, but this morning it was 20deg in my garage and it did not pop up, so I had to do the door trick.
Old Jan 29, 2007 | 10:20 PM
TEC6's Avatar
TEC6
St. Jude Donor '10-'11
mine does the same thing..
To Opening Trunk Lid, Convertible
Old Jan 30, 2007 | 12:37 AM
RockyL32's Avatar
RockyL32
From: If your not the lead dog the view never changes Boise, Id
I had the same problem. After many WD-40 aplications I decided to bond a flat spring in the gutter right behinde the latch mechanism. Trunk now pops up every time
Old Jan 30, 2007 | 07:44 AM
VET IT B's Avatar
VET IT B
Adjust the springs, lube all moving parts and clean and lube the weather strips. Do these and problem solved. Mark
Old Jan 30, 2007 | 08:49 AM
Fourtrax250R's Avatar
Fourtrax250R
my 01 vert does the same thing, and my buddies 04 vert also has the problem, especially when its cold out, I will try the "door method" and wd-40 to lube her up, Thanx guys!
