[Z06] Shift Knob - making the shifter "shorter"
Old Jan 31, 2007 | 11:26 PM
Weedo's Avatar
Weedo
Default Shift **** - making the shifter "shorter"
I really like the old MGW Pistol Grip. After doing some research it appears it's no longer made.
Can anyone recommend a shift **** that is similar? I like the fact that it was a small ****. I'd like something that will essentially lower the shfter height by an inch or so.
Old Feb 1, 2007 | 06:22 AM
mitchcole's Avatar
mitchcole
I changed to a cue ball and the height was initially too high as well. The shaft goes sooooo far into the original **** - that as soon as you put something else on there it actually lifts the whole thing up.
SoI very carefully used a cutoff wheel (3.5" pneumatic) and some well placed towels to cut off about an inch of the original shaft. There's no going back from here.
Old Feb 1, 2007 | 08:27 AM
v03z06's Avatar
v03z06
Can anyone recommend a shift **** that is similar? I like the fact that it was a small ****. I'd like something that will essentially lower the shifter height by an inch or so.
Maybe switching to the C6Z shifter would help. It is supposedly about an inch or a little more shorter than ours.
Old Feb 1, 2007 | 09:36 AM
TEXHAWK0's Avatar
TEXHAWK0
The classic Hurst shifter ***** will thread all the way down and shorten the shifter height. I extended the threads on the stock shifter, then cut the top off the shaft.
Old Feb 1, 2007 | 09:44 AM
TEXHAWK0's Avatar
TEXHAWK0
Or you could just go with the Hurst shifter where the shaft is already shorter.
Old Feb 1, 2007 | 10:15 AM
HP_Addict's Avatar
HP_Addict
I get the naming confused, but is the pistol grip the round cylinder looking ****? I swapped my cylinder style MGW **** out for a MGW gripper ****(the ball style). I have the other one sitting on my coffe table, if you want it I can sell it to you. Shoot me a PM if interested.
Old Feb 1, 2007 | 06:04 PM
jpandes's Avatar
jpandes
Default The Delrin Shift **** off Ebay
I bought both the Delrin Shift **** and the Classic Hurst Pool Ball shift **** and I found that I really like the delrin **** better. It does shorten the height and you can also grip the shifter lower since its essentially the same thickness as the shifter below the boot.
I have a hurst short shifter sitting in my garage right now but have not had the urge to install it. Partially beacause this delrin **** is that good. BTW, I have a black practially bran new Hurst Classic shift **** for sale $30 shipped...
http://cgi.ebay.com/ebaymotors/C5-Z0...spagenameZWDVW
Old Feb 1, 2007 | 06:35 PM
Weedo's Avatar
Weedo
PM sent!
I'm trying to decide between a shortened stock shifter (probably the route i'll take) or an aftermarket that doesn't require an arm workout to shift. Either way I want to find a **** that lowers the height as well.
jpandes - how much lower did the Delrin mod make the overall height? Probalby not something you measured...
Old Feb 1, 2007 | 10:03 PM
Tourmgr1's Avatar
Tourmgr1
I have the Delrin shift **** that jpandes has and it's pretty nice .....I think it dropped the height 1.5 inchs ...do a search.
Good Luck.
Old Mar 17, 2007 | 06:22 PM
speedy77's Avatar
speedy77
I cut my stock shifter down 1-1/2", then ground a little of the taper so it could be thread even lower, then ran a die all the way down to the fat part of the shifter. For me it was the perfect hieght. I tried several ***** & all where fine.
Don't know what GM was thinking when they put it up so high !
PS...I had to trim the top of the boot also.
Old Mar 18, 2007 | 01:24 AM
Steve Theodore's Avatar
Steve Theodore
Thanks to the information on this thread, I'm going to try out the Delrin C5R style **** from eBay. I appreciate the recommendation!
Old Mar 19, 2007 | 03:33 PM
redroket's Avatar
redroket
How much of a pain was this to do? I want to do it also but my car is a daily driver so I don't want it down for a day or two while I screw around with the shifter.
Old Mar 19, 2007 | 09:28 PM
speedy77's Avatar
speedy77
Default Cut down stock shifter
Very easy, about an 1-1/2hr job. All you need is a hacksaw & 9/16-18 thread die. I did it right in the car. You may want to only cut an 1" off, I gound down at the bottom so could go as low as possible, but I cut off an 1-1/2". I'm a mechanic, so this was easy for me but it wasn't a hard job with the right tools. I thought it was a great up-grade for FREE. My shift **** looks like crap because of the coating wearing off, but this is what it looks like, I love it like this. Email with any questions. Thanks, Steve
Old Mar 19, 2007 | 10:33 PM
redroket's Avatar
redroket
Thanks for the info Steve! Thats great I don't have to take it out of the car. I do have air tools and such but just a hacksaw sounds okay. I may do it this week!
Regards,
Dale
Old Mar 20, 2007 | 07:14 PM
speedy77's Avatar
speedy77
PS...you may have to put a thin washer or 2 inside the shift **** because when you tighten the **** down it may not be in the right position. Good luck....I'm sure you'll like the results. I was nervous about doing it at first but no regrets.
Old Mar 21, 2007 | 09:59 AM
Wah's Avatar
Wah
I removed the black sleeve and the rubber damper inside of it. What's left is a small stub that used to be inside the sleeve. It makes the shifter shorter by almost 3".
Old Mar 21, 2007 | 10:55 AM
BitViper's Avatar
BitViper
I just took a hack saw and wacked off ~1"..worked great
BTW... The B&M and the Hurst are both the same lenght as the stock one after cutting an inch off....
Old Mar 21, 2007 | 02:49 PM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
I cut about an inch off mine with a dremel without removing the shifter, the **** I have does not screw on so I didnt worry about the threads.Still too high but better.
To Shift Knob - making the shifter "shorter"
