Auto Passenger Door Opener won't work?
Old Feb 1, 2007 | 05:02 PM
Bob Lapine's Avatar
Bob Lapine
Default Auto Passenger Door Opener won't work?
The passenger door on my 02 Convertible will not unlock with the key FOB while outside the car, but it locks normally. The drivers door works great when locking and unlocking as does the trunk. Has anyone out there had the same problem? Can I fix it myself? Or do I have to bite the bullet and take it to the dreaded dealer?
Any suggestions as to this problem will greatly be appreciated.
Thanks in advance for any suggestions.
Old Feb 1, 2007 | 05:41 PM
Bill Vett's Avatar
Bill Vett
look on the dic and see what the settings are. I think that there's a setting for unlock both..
Old Feb 1, 2007 | 05:56 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Hi Bob, Just for clarity, do you mean that when you press unlock twice on the FOB, the passenger door does not unlock? If that's true, then when you press lock on the FOB, do both doors lock?
Old Feb 1, 2007 | 09:54 PM
Bob Lapine's Avatar
Bob Lapine
Default To: ptdrummer54
Thanks for your reply; yes, when I click on the FOB to lock the car it will lock both doors! When I double click on the FOB to unlock the doors it will only unlock the Drivers Door, then I have to go inside the car and manually open the door lock for my wife to get in.
Do you have any ideas?
Thanks for your help
Old Feb 1, 2007 | 10:58 PM
silverbullit99's Avatar
silverbullit99
I have this problem as well, sometimes it works sometimes it doesn't. I read somewhere in this forum that it could be the contact switch in the door. You might be able to take it out and clean it, but I haven't tried that yet. They say that the switch is expensive to replace,,
Old Feb 1, 2007 | 11:37 PM
BlackWidow01's Avatar
BlackWidow01
I had the same problem awhile back. I replaced the door control module. Now it works beautifully. I found a used one for $100 and did the labor myself.
F.Y.I. The dealer wanted $399 for the module plus labor.
Old Feb 2, 2007 | 01:06 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
bingo we have a winner - well most likely. They fail all the time. Lost my drivers side. Glad I had the window valet to open and the window and then unlock the door.
Old Feb 2, 2007 | 01:14 AM
DeeGee's Avatar
DeeGee
Me too.
I had the door control module changed - it was a problem with output voltage - and problem solved. There's a DIY How To out there somewhere. It shows how to strip down the module and change the lock or unlock relays. I'll post a link if I can find it.
Old Feb 2, 2007 | 08:38 AM
Rex99Coupe's Avatar
Rex99Coupe
http://forums.corvetteforum.com/show....php?t=1218327
or
http://forums.corvetteforum.com/show....php?t=1606865
To Auto Passenger Door Opener won't work?
