Clean Engine Bay
Old Feb 6, 2007 | 03:24 PM
AMRAAM's Avatar
AMRAAM
Originally Posted by bonnell
Check on http://www.adamspolishes.com/
They have a video showing exactly what you want.
In the video, he calls the stuff he is using "all purpose cleaner". I can't seem to find it on the website. Which bottle is it?
Old Feb 6, 2007 | 03:43 PM
2fat2fly's Avatar
2fat2fly
Originally Posted by JEEP/C5
Search this question - its been asked before and several members said that simple green will run the finish on aluminum parts. I wipe mine down when once a week with an old cotton sock - sometimes dry and sometime wet (the sock stays on your hand so you dont have to hold it plus protect your hand form cuts and scraps) and after I wash the outside I wipe under the hood and then use Son of a Gun tire foam on everything then wipe up the excess. It turns out great and has a high gloss finish. Makes all hoses and belts look like new. The Son of a Gun will make dust stick to it so it may not be great for DD (quick and easy for car shows). Some use a hood seal to help keep dust out as well.
The simple green will mess up unfinished aluminum if you spray it on without first diluting it,especially if you let it sit without immediately washing and rinsing the part.I learned that the hard way on a motorcycle.
Old Feb 6, 2007 | 04:48 PM
PashaCorvette's Avatar
PashaCorvette
The idea of using the water to clean the engine bay or under the hood isn`t for me cause it`s a big possibility that water can ruin all those electrical devices and such.I use wet towel the wipe the dirt off it takes time but at least much more safer,than use almoral or maguire for making it look clean and shiny here is the result........
Old Feb 6, 2007 | 06:58 PM
Oldvetter's Avatar
Oldvetter
There is a Technical Service Bulletin (TSB) out on how washing engine with water can damage the knock sensors (under the manifold). It tells you to build an RTV dam when replacing to keep water out.
Simple Green will corrode aluminum.
Old Feb 6, 2007 | 07:04 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
I agree with some that are less than enthusiastic about using ANY water in the engine compartment what with all the connectors,grounds,tunnels under the battery leading to the PCM, etc. My vert is 5 years old and I've been cleaning the engine bay the "hard way" all this time by hand and would love to Gunk it/rinse with hose and blow dry. I just can't get past the possibility of corrosion causing electronic/electrical problems. Have always been able to "hose down" every car,truck,boat,motorcycle I've ever owned but this deal, I don't know?
Old Feb 6, 2007 | 08:16 PM
bonnell's Avatar
bonnell
I have not bought the package yet. I watched all of the videos and decided to buy the complete kit but have not yet. According to the videos I watched it is used on the wheels as well as the engine.
Email Heather at Adams and she will tell you.
