Clean Engine Bay
Old Feb 5, 2007 | 02:37 PM
chai1836's Avatar
chai1836
Default Clean Engine Bay
What is the best way to clean an engine bay? Can you spray water directly on the engine? Are there any cleaning solutions that are made for engines?
Old Feb 5, 2007 | 02:43 PM
kromberg's Avatar
kromberg
Be interested in to see peoples approaches to this.
Keith
Old Feb 5, 2007 | 03:34 PM
Blown 346's Avatar
Blown 346
I drive my car to the self serve pressure car wash.
I pop the hood, spray the motor down with soap and rest the hood on the latch. This lest all the dirt/grim soak and bake off. I wash the rest of the car etc. After that I lift the hood, and rinse. Drive the car home lift the hood, and everything is spotless, wipe down what little water is left.
Old Feb 5, 2007 | 04:06 PM
Ron71's Avatar
Ron71
I spray my engine bay down with some diluted simple green and water from the hose and let sit a few minutes. Then I rinse thoroughly and dry off with a leaf blower. Works for me.
Old Feb 5, 2007 | 04:17 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
The "Simple Green" method is the most popular.
Old Feb 5, 2007 | 04:18 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
I did the same thing to get the initial grease/grime off.
After that, I simply just lightly mist the engine bay with garden hose each time I wash the car then use the blower and follow up with a towel.
I also always cover the alternator and fuse block area with foil or plastic before misting or using any water.
chai1836's Avatar
chai1836
Great advice, I will try that....even though simple green brings back bad Navy memories.
Old Feb 5, 2007 | 04:20 PM
korte's Avatar
korte
haha.. you know we still use that.
Old Feb 5, 2007 | 04:21 PM
chai1836's Avatar
chai1836
I don't doubt it, I got out in 2000 and I can still smell that crap everytime I blow my nose....lol
Old Feb 5, 2007 | 04:22 PM
JEEP/C5's Avatar
JEEP/C5
Search this question - its been asked before and several members said that simple green will run the finish on aluminum parts. I wipe mine down when once a week with an old cotton sock - sometimes dry and sometime wet (the sock stays on your hand so you dont have to hold it plus protect your hand form cuts and scraps) and after I wash the outside I wipe under the hood and then use Son of a Gun tire foam on everything then wipe up the excess. It turns out great and has a high gloss finish. Makes all hoses and belts look like new. The Son of a Gun will make dust stick to it so it may not be great for DD (quick and easy for car shows). Some use a hood seal to help keep dust out as well.
Old Feb 5, 2007 | 05:04 PM
tigerman's Avatar
tigerman
I use a tooth brush and some brake cleaner on the block and little bit of soap and spray bottle on the rest then touch it up with some rubber plastic shine spray....they all work.....cheers
teagueO's Avatar
teagueO
There is a video of washing a C5 motor on Adams polishes web site.
Very helpful, I found.
Old Feb 5, 2007 | 05:14 PM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
This one looked interesting to me. I haven't tried it yet, and my engine bay never looked this bad, but....
File Type: pdf
Old Feb 5, 2007 | 05:42 PM
LMB-Z's Avatar
LMB-Z
As some have said, simple green CAN harm certain metals if not used correctly. It must be diluted. I sprayed it on my Silverado wheels and the clear coat came off when I rinsed it off 2 minutes later. I take mine to the car wash and use the pressure washer, just being careful where I point the water spray. Don't spray directly on a hot motor until you cool it off a little at a time. Wipe with Armoral to get that shine.
Old Feb 5, 2007 | 07:45 PM
mitch1959's Avatar
mitch1959
Simplen green and a hose,blow dry than use Adams In & Out detail spray keeps it looking new !!!!
Old Feb 5, 2007 | 07:49 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
plus I have the engine running while I hose it down. Simple move the hose if the enginee sputters.
Old Feb 5, 2007 | 08:07 PM
MonteHall's Avatar
MonteHall
St. Donor '03 & '06
I was told not to use pressure washers to clean an engine as it will force water into places water shouldn't be.
To Clean Engine Bay
Old Feb 6, 2007 | 12:25 PM
jovette's Avatar
jovette
I agree with the sock method. I don't use simple green anymore after reading about the chance of it effecting the finish on some aluminum parts. I use an Eagle brand cleaner, that works kind of like armorall, but does not have a glossy sheen to it, rather it leaves a more natural look to vinyl, rubber, and plastic.
Old Feb 6, 2007 | 12:39 PM
LRD VDR's Avatar
LRD VDR
Simple green also.
Shahram
Old Feb 6, 2007 | 02:28 PM
bonnell's Avatar
bonnell
Check on http://www.adamspolishes.com/
They have a video showing exactly what you want.
