18 inch Wheels all around
Old Feb 5, 2007 | 09:37 PM
jrose7004's Avatar
jrose7004
Default 18 inch Wheels all around
I'm getting new wheels for my C5 Coupe and have decided on 18" wheels all the way around. The fronts are 18 X 8.5 and the rears are 18 X 9.5. I'm planning on keeping the stock size P275/40 ZR 18's in the back and I'm confused on what size tire to put on the front to keep the right look! What would be right size to run upfront?
Old Feb 5, 2007 | 11:49 PM
wamara's Avatar
wamara
Cruise-In II Veteran
Use a calculator such as this,
http://www.miata.net/garage/tirecalc.html
in conjunction with the tire mfr's wheel width recommendations.
Old Feb 6, 2007 | 12:06 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Since you are not going any wider than stock - the widest tire you can fit is a 255-40x18. That tire 26" tall, so you might consider a 255-35x18 which is 25" tall and will better maintain the stagger with the stock size.
But why are you limiting yourself to these sizes?
BTW - my source of information is the Michelin web site....
http://www.michelinman.com/specs/pil..._ps2/2958.html
Old Feb 6, 2007 | 12:42 AM
jrose7004's Avatar
jrose7004
I guess the next question is will a 18 inch wheel and different size tire affect the speedometer reading?
Old Feb 6, 2007 | 01:29 AM
99Lingenfelter's Avatar
99Lingenfelter
St. Jude Donor '07
I almost bought a set of 18x8.5 front and 18x9.5 rears today. After a ton of research and help from other CF members, I've decided to keep the 17's front and 18's rear. I figure GM did it for a reason also, give the cars a slight sloped look.
If you are going to go 18's all the way around, put some 245/40/18's up front, they're the same size as the stock 245/45/17's.
Old Feb 6, 2007 | 01:30 AM
99Lingenfelter
St. Jude Donor '07
Ohh, and by the way, this is for everyone... this is the coolest tire size calculator I have found. Let me know if you have a better one.
Old Feb 6, 2007 | 03:43 AM
davisce's Avatar
davisce
Dude,
I'm running 18's all around also, but I have 18x9.5 front and 18x11 on the rear.
I'm running 265/35x18 tires on the front and 295/35-18 tires on the rear. No problems. . .
Ciao,
Old Feb 6, 2007 | 07:11 AM
W.A.M.'s Avatar
W.A.M.
Old Feb 6, 2007 | 07:28 AM
AU N EGL's Avatar
AU N EGL
Right look?
Heck if your driving you dont see the wheels.
18s here too.
18x12 with 18x305/30 front and 18x13 with 18x335/30 rear
Old Feb 6, 2007 | 07:34 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
running 295 front and 315 rear on 18. although this is a good track setup the 295 fronts are too wide for most roads.
Old Feb 6, 2007 | 01:15 PM
99Lingenfelter
St. Jude Donor '07
Could some of you guys with 18's all around post some side pics. I was going to order the 17's and 18's but if the 18's all around look good, I might just stick with those.
Old Feb 6, 2007 | 01:52 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
I'm running 18x9.5 w/ a 275 up front and 18x11 rear w/ a 295.
Old Feb 6, 2007 | 02:11 PM
Lancer033's Avatar
Lancer033
I'm running the same tires as Cobra on 18x9.5,18x10.5 Z06 motorsport wheels
The ABS/AH/TC/Speedometer don't care about the diameter of the wheels, only the outer diameter of the tires.
Old Feb 6, 2007 | 06:53 PM
99 vett babycar's Avatar
99 vett babycar
To 18 inch Wheels all around
