[Z06] rear abs/tc sensor
Feb 7, 2007 | 05:10 PM
rear abs/tc sensor
can anyone tell me where this is located? I think mine is shot and needs replacement...also, how much does this go for?
Feb 7, 2007 | 11:16 PM
Quote:
Originally Posted by
why_ask_why
Each wheel has a Wheel Speed Sensor, and they are mounted in the wheel hub. The EBCM uses the four sensors for ABS/TC along with other inputs.
What makes you think your "sensor" is going bad? Have you checked for DTC code(s) via the DIC ??
If you have codes post them and someone will help you in diagnosing the problem.
Feb 8, 2007 | 10:39 AM
BlackZ06
thanks for the info...I'll go check the codes when I go outside for a smoke break later
