Headlight closes then opens again
I recently had a stripped gear on the drivers side headlight (2001 C5). I replaced the gear and it worked perfectly for a month or so. Now when I switch the car off, or switch the headlights off, both headlights close, but then the drivers side one comes up again. The actual headlight itself is not on so it does not flatten the battery.
I tried manually winding the headlight down, but you still get the same problem next time you switch the headlights on then off, i.e, the one light pops again again.
Anyone experience this before.
send me an email and I will forward it to you.
It has to do with adding washers to the mounting bracket on just the drivers headlight.
