[Z06] Wrong oil?
Old Feb 12, 2007 | 05:25 PM
Sloo_Dc2's Avatar
Sloo_Dc2
Default Wrong oil?
I changed my oil today with royal purple 5w30 and realized I had put a half quart of 5w20 in by mistake. Is this that big of a deal or should I change my oil again?
Old Feb 12, 2007 | 05:37 PM
thehammer69's Avatar
thehammer69
Trust me...don't worry one tiny bit about it.
Hammer
Old Feb 12, 2007 | 06:05 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi Sloo_Dc2-
Nothing to worry about.
best regards -
mqqn
Old Feb 12, 2007 | 06:08 PM
Sloo_Dc2's Avatar
Sloo_Dc2
Hey, thanks a lot guys, I really appreciate it! I have a tendency to get very paranoid about that sort of stuff, I guess it's just part of me being so **** retentive!
Old Feb 12, 2007 | 07:54 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Run it! NO PROBLEMS !
BC
Old Feb 13, 2007 | 08:14 AM
SweetZO6's Avatar
SweetZO6
Default Run it!
When I changed the oil in my Z the first time (purchased with 9,000 miles) I used RP 15W-40 since that is what I use in everything and I have it in bulk. So I dropped RP an email and asked if running the heavier weight 15W-40 oil would hurt anything. RP said no but would recommend using RP 5W-30 or RP RACING 21 oil. Of course I asked why. RP said that the heavier 15W-40 does not circulate as fast in the engine as the RACING 21, therefore, the 15W-40 does not absorb and disipate the heat as rapidly as the RACING 21. And it is all about getting the heat out of the bearings, etc..
Ed
Old Feb 13, 2007 | 12:07 PM
FasterIsBetter's Avatar
FasterIsBetter
As long as it's the same brand of oil, absolutely no problem mixing it. Different brands use different combinations of additives, and mixing brands can change the effectiveness of additives. But one quart is probably not enough to hurt anything. If it was the same brand, the additive package is probably the same or very close to the same, so absolutely no problem.
Now go drive it like you stole it.
Old Feb 13, 2007 | 12:26 PM
mr-z's Avatar
mr-z
don't worry
Old Feb 13, 2007 | 03:34 PM
Z-THREAT's Avatar
Z-THREAT
I've talked to a Volvo engineer and all oils are made to be compatible. Goverment regulation. Also if you wanted "some" synthetic protection, the so called "blends", all you have to do is add a quart of synthetic to your regular oil. In the vettes or other high performance just put all synthetic.
Best Regards-
John
Old Feb 13, 2007 | 04:26 PM
Tom/99's Avatar
Tom/99
I should be no problem, don't worry about it.
Old Feb 14, 2007 | 03:42 AM
skeet's Avatar
skeet
With Mobil 1's OK I run a 7 1/2 x 30 as they said it was OK to run 3 1/2 qts of 5-30 and 3 1/2 qts of 10-30. I just do not like a 5-30 oil and this is as close to it as I will go for winter driving. In summer I use a only 10-30.
Old Feb 14, 2007 | 10:19 AM
thehammer69
I'm not against mixing oil...I've done it myself. But you are making a mistake here. Believe it or not, Mobil-1 5w-30 is actually THICKER at operating temp than 10w-30. Let's focus on the "30" number for a second. That is the SAE viscosity rating for when the oil temperature is 212F/100C. Ok, now understand that a SAE 30 viscosity has approximately a 9.5 cSt-12.6 cSt viscosity range....So basically there can be close to 3 cSt variance in viscosity and still be called a SAE 30. Well here's the thing, Mobil-1 5w-30 runs higher in this range than 10w-30 at operating temp. You see, if you take time to read the Product Data Sheets (PDS) on both these Mobil-1 oils, you will find that the 10w-30 runs close to 10cSt while the 5w-30 runs at around 11 cSt.
So basically, you are actually slightly thinning out your 5w-30 at operating temperature when you are mixing these two because you now end up with around a 10.5cSt product. Will it hurt you, probably not one bit. But non the less, you are mistaken in your end desired results.
Hammer
Old Feb 14, 2007 | 12:47 PM
DPG's Avatar
DPG
St. Jude Donor '06
Originally Posted by thehammer69
I'm not against mixing oil...I've done it myself. But you are making a mistake here. Believe it or not, Mobil-1 5w-30 is actually THICKER at operating temp than 10w-30. Let's focus on the "30" number for a second. That is the SAE viscosity rating for when the oil temperature is 212F/100C. Ok, now understand that a SAE 30 visocosity has approximately a 9.5 cSt-12.6 cSt visocosity range....So basically there can be close to 3 cSt variance in visocosity and still be called a SAE 30. Well here's the thing, Mobil-1 5w-30 runs higher in this range than 10w-30 at operatingf temp. You see, if you take time to read the Product Data Sheets (PDS) on both these Mobil-1 oils, you will find that the 10w-30 runs close to 10cSt while the 5w-30 runs at around 11 cSt.
Hammer
Hammer good info and also good to know
To Wrong oil?
