Service Column Lock
Old Feb 28, 2007 | 03:49 PM
VetteBandit's Avatar
VetteBandit
Originally Posted by 03aaron
is there a way to see if its already been done to the car.....
thanks
aaron
Call up your local Chevy dealer and they can look up by VIN if it was serviced under warranty. For after market fixes you have to look to see if the bypass harness has been installed. Only certain years need the harness - others are just a computer re-program. There is a thread that gives a detailed explanation about the entire Column Lock issue and its solutions.
http://forums.corvetteforum.com/show...ht=column+lock
Old Feb 28, 2007 | 04:03 PM
LeeJones's Avatar
LeeJones
From: I saw her today at the reception.....a glass of wine in her hand...
Originally Posted by RFS-Z06
Got letter from Chevy saying they will cover cost to fix it. Do you still recomend the bypass switch??????????
nope......
Old Feb 28, 2007 | 04:04 PM
LeeJones's Avatar
LeeJones
Originally Posted by troopersheriff391
GM has put out safety recall. They will remove the locking plate and reset the program for FREE. Had mine done Monday and no more locking the column. It's about time they own up to the dangerous problem.
Old Feb 28, 2007 | 04:07 PM
kilrb's Avatar
kilrb
I had no choice but to do the recall; my column locked up and wouldn't unlock. After I received the car back, I have had the "remove key, wait 10 seconds" message twice, but after doing so, the car worked. It's been a week now, and the two errors came up early on. I hope it isn't something that hpapens fairly often...
Old Feb 28, 2007 | 04:14 PM
87SAM's Avatar
87SAM
Time's a wastin, better get the CLB now!
Old Feb 28, 2007 | 06:24 PM
M6 Vetter's Avatar
M6 Vetter
Get the CLB and be done with the worries
Old Feb 28, 2007 | 06:30 PM
ceosjmh's Avatar
ceosjmh
Cruising
Default column lock
Does anyone know if column lock has been responsible for a driver
fatality?
Old Feb 28, 2007 | 06:33 PM
korte's Avatar
korte
Well, since my car has the ultra-cool POWER telescoping steering column, dont think i have to worry about this!
Originally Posted by old55
Plus if you have the Dealer do it they will re flash the PCM programming in the unwanted Fuel shut off feature, that isn't in the car now.
What's that? The new program will shut off your fuel? Please elaborate..
Old Mar 25, 2007 | 02:21 AM
yaknow's Avatar
yaknow
fatality?
If you can not start your car or can only drive at 2mph what is the chance of a drivers fatality?
Old Mar 26, 2007 | 06:39 AM
TonyNDeb's Avatar
TonyNDeb
In my case, it's a fatality by embarrassment. Mine did it at Jenro's, after the Vettes at Waterside event. Talk about being extremely upset, nothing like your car killing itself in front of about 20 other Vette owners that probably thought I couldn't drive my own car.
