another fog light question
Old Feb 13, 2007 | 11:20 AM
casisthefirst's Avatar
casisthefirst
Default another fog light question
Does anyone know the dimensions of the stock fog lamps?
(height, width, and depth)
Im thinking of buying new fog lamps and my vette is currently in the body shop at this time so I have no access to measure them.
(I asked back in the tech section, but I know many people usually dont have time to go back and fourth between sections, plus I am a bit pressed for time to make my purchase...so I apologize for taking up some space here...)
Thanks in advance!
Old Feb 13, 2007 | 02:22 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
PM vendor Tuan Le...
Old Feb 13, 2007 | 06:34 PM
BanditDude's Avatar
BanditDude
What dimensions are you wanting? I have a pair on the shelf. Here are some rough measurements (using cheap tools):
Front to rear of housing. 105mm
Lens protrusion (bulge) 13mm
Outer diameter 59mm
lens diameter 46mm
front of housing to mounting bolts 30mm
width between the mounting bolts 73mm
Let me know if you need anything else. I also recommend Tuan Le, and bought some PIAA 1100x from him last year. Good luck!
(I corrected a few numbers)
To another fog light question
