[Z06] Oil leak
Old Feb 13, 2007 | 08:38 PM
Achilles's Avatar
Achilles
Default Oil leak
I was just wodering if these ZO6's are prone to oil leaks around the oil filter. I had no leaks prior to an oil change. Now I have a small drip off the pan near the oil filter. I changed out the filter just in case, but it's not the filter leaking. Thing is, I only have 17k miles on my '03, I don't think it should be leaking motor oil. I have a GM extended warranty, but I hate having the car in the shop.
What's up?
Old Feb 14, 2007 | 08:54 AM
Twil1ght's Avatar
Twil1ght
No that's not common. Can you narrow down where it is leaking from? Some people have complained of a pan leak in the corners.
Old Feb 14, 2007 | 10:00 AM
Achilles's Avatar
Achilles
That seems to be the area of the leak. The drip appears around one of the pan bolts next to the filter, but oil residue is up higher in the casing around the filter. It could just be a loose pan bolt and the oil is getting blown up the casing, but funny thing is the filter is bone dry. I thought it might be a rear seal. Just seams unusual for a low mileage car to develop oil leaks.
Old Feb 14, 2007 | 10:17 AM
RobG03Z06's Avatar
RobG03Z06
St. Jude Donor '08
No oil leaks on my '03Z06...14200 miles on it. Yea, it's a garage queen, only driven on weekends when the weather is nice.
To Oil leak
