What size would you go?
Old Feb 15, 2007 | 12:38 PM
culookin06's Avatar
culookin06
Default What size would you go?
I am going to the Kuhmo MX series and want to know what would work on the front of my 97 C5 on wagon wheels? I have stock size Kuhmo SPT's all around now. I do have it lowered and will be going with the 295/35/18 on the rear once they wear out this summer. Any input would really help me make a decision. Thanks a million!
Old Feb 15, 2007 | 04:16 PM
jbauch357's Avatar
jbauch357
you may want to take a look here: http://www.kumhousa.com/print_specs.jsp?pid=KU15
if the factory wagon wheels on the rear are 9.5" wide you may see some fitment issues trying to cram on a 295/35/18
On Z06 rims I am running
REAR - 295/35/18 (10.5" wide wheel)
FRONT - 275/40/17 (9.5" wide wheel)
Old Feb 15, 2007 | 04:20 PM
DefenderC5's Avatar
DefenderC5
I have stock size wheels as well, you will want a 275 on the rear. In the end I just went with stock sizes for my Kumho SPT. Wont hurt anything
Old Feb 15, 2007 | 04:28 PM
gpracer1's Avatar
gpracer1
That is pretty wide up front. Does it rub at all? Does it fit the rim correctly? I was thinking of the same set up.
How does that baby handle?
Old Feb 15, 2007 | 04:53 PM
jbauch357's Avatar
jbauch357
No rubbing issues what so ever. It still has the factory Z06 alignment which is pretty agressive - and corners like it's on rails...
Old Feb 15, 2007 | 05:44 PM
culookin06's Avatar
culookin06
I ended up just staying with stock size but am upgrading to the MX series. Thanks so much for the input. It's good to be back on the forum.
To What size would you go?
