HUD Question
Old Feb 19, 2007 | 10:32 AM
Z06Aggie's Avatar
Z06Aggie
Default HUD Question
My HUD is set to show fuel level, but once every 4 or 5 times that I crank it up, it has changed to the temp, or oil gage. What would cause this?
Old Feb 19, 2007 | 12:20 PM
rbrtclk's Avatar
rbrtclk
Battery getting ready to quit.
Old Feb 19, 2007 | 12:45 PM
Lightgomez's Avatar
Lightgomez
Mine did the EXACT same thing. You might also look at your DIC as well. Mine would change back to the odometer reading everrytime I would start the car and pretty much every thing else would Zero" out. Once I changed out the battery, problem is gone.
Old Feb 19, 2007 | 12:56 PM
Z06Aggie's Avatar
Z06Aggie
Old Feb 20, 2007 | 07:26 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
w/ all of the above. Same thing happened to me b/4 my 3rd (and last) Optima Red Top died out on me. Installed a new battery (Sears DieHard) and problem was gone. Good luck...
Old Feb 20, 2007 | 12:15 PM
07blackcoupe's Avatar
07blackcoupe
From: Lost in the Pine Barrens with only ketchup and relish packs, New Jersey
If you disconnect the battery, it will go to oil, not temperature. I quess that is the default setting for the HUD. If yours goes to something other than oil, it might not be the battery...
Old Feb 20, 2007 | 12:57 PM
I'll join in with the majority and say the battery is the culprit.
Old Feb 20, 2007 | 03:24 PM
DeeGee's Avatar
DeeGee
Old Feb 20, 2007 | 03:57 PM
RamjetVette's Avatar
RamjetVette
Then one day, it don't start.
Old Feb 20, 2007 | 03:59 PM
Fourtrax250R's Avatar
Fourtrax250R
Old Feb 20, 2007 | 09:43 PM
Z06Aggie's Avatar
Z06Aggie
I guess it's a nice way of warning you before it happens. At least I won't be as suprised.
To HUD Question
