AC/heating system
Old Feb 20, 2007 | 08:27 AM
darkriderzx10's Avatar
darkriderzx10
Default AC/heating system
Hello all. I have an 1998 c5 and i recently replaced my ac/heater cluster because the bulb or lights wouldnt show up. Now the problem im facing is that I get heat on my passengers side but on the drivers side I get no heat. What could be the possible solution to this. I was thinking theromstat? But I find it werd that it works fine on the passengers side. Your help will be greatly appreciated.
Old Apr 2, 2007 | 11:34 AM
gbm's Avatar
gbm
Default Heating problem
Did you ever figure this out? I had the same thing just happen.
Old Apr 2, 2007 | 09:58 PM
darkriderzx10
i had to replace the whole unit..
Old Apr 16, 2007 | 03:41 PM
gbm's Avatar
gbm
what did that set you back?
Old Apr 16, 2007 | 04:38 PM
TLewis4095's Avatar
TLewis4095
It is the diverter doors, the motors are out of sync or one may have a stripped gear.
We have an entire dual control unit here for $200 if you want, but to at least get cold air go through the DIC codes & clear the havac ones, it will try to reset in sync. May work, may not.
Old Apr 16, 2007 | 05:43 PM
gbm's Avatar
gbm
I do get cold air only on my driver's side; no hot. No codes have been thrown. Reset power and still the same.
Old Apr 16, 2007 | 06:01 PM
rtagz's Avatar
rtagz
Cruise-In IX Veteran
http://forums.corvetteforum.com/show....php?t=1677807
See post #23 for pictures of the bulbs that light up your buttons,
See post #42 for pictures of the contacts to re-solder for your display.
We just did J.P.M.'s HVAC controll on Saturday, re-soldered the 8 contacts and the display works just fine, he has to order new LED's and we will replace the bulbs.
This way since you have your old unit out, you can fix it, then send the one you just bought back for a refund.
Good luck.
Old Apr 17, 2007 | 05:02 PM
gbm's Avatar
gbm
Found B0441. - Left acuator out of range.
Thanks to several folks, there's a ton of info on this.
http://forums.corvetteforum.com/show...=b0441:toetap:
Old May 31, 2007 | 04:39 PM
gbm's Avatar
gbm
Replaced the acuator and resolved the issue. chaulk it up to another pos component.
To AC/heating system
