Tire sensors
Old Feb 20, 2007 | 10:37 PM
rkhegler's Avatar
rkhegler
Default Tire sensors
What is it to change these out when you are putting on new rims?
Old Feb 20, 2007 | 10:51 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
It's easy. The main body goes inside the wheel, with the valve stem protruding through the hole. You tighten the nut down the valve stem. This presumes that you buy wheels that are made for the sensors...
Old Feb 21, 2007 | 02:18 AM
Choreo's Avatar
Choreo
Had all mine replaced at Discount Tire yesterday and questioned them ahead of time about meeting the recommended inch-lbs torque value. They had just received a new tire-sensor torque tool that had a blue knurled shaft and looked like a fat screwdriver with a T-handle on top. It would click when the proper valve-stem torque was reached. Under or over tightening could be a problem.
Old Feb 21, 2007 | 04:13 AM
NOWUCME's Avatar
NOWUCME
C6 of Year Finalist (stock) 2019
When you get the tires back on then you have to reset the sensors by wheel so you can tell which tire is being read. Search tire sensors and you will find a thread on sequence to follow. All you need is a magnet, i used one of those small ones that telescope out and it worked. You use the DIC and follow the sequence by wheel, RF, LF, etc.
Old Feb 21, 2007 | 07:34 AM
rkhegler's Avatar
rkhegler
Thanks. I will give it a try!
Old Feb 21, 2007 | 09:16 AM
jrose7004's Avatar
jrose7004
For a good deal on them try www.gmpartshouse.com
Old Feb 21, 2007 | 10:13 AM
wamara's Avatar
wamara
Cruise-In II Veteran
Why recommend extra work? If he is reusing his TPS, as long as the TPS goes back to its original position on the car (i.e. LF, RF, LR, RR), he will not have to retrain the sensors. Now admittedly the tire monkey may not keep track of which is which, but he can.
Old Feb 21, 2007 | 12:01 PM
OleStraightStick's Avatar
OleStraightStick
St. Jude Donor '08
i had a nail patched in my driver side rear a short while back by L&M tires, and ever since it randomly says tire mon. sys. malf. doest that mean they didnt reset it properly when they put the tire back on?
Old Feb 21, 2007 | 12:17 PM
wamara's Avatar
wamara
Hard to say what is causing this. Hopefully they didn't damage the sensor when they removed the tire from the wheel. Theoretically, there should be nothing to reset, but frankly all these electronics sometimes cause gremlins that even the engineers can't figure out. In your case, it probably would be worth retraining (or at least trying to retrain) the sensor - start with the easy remedies first!! Good luck.
Old Feb 21, 2007 | 01:32 PM
JJ 86's Avatar
JJ 86
How big of a magnet do you need to reprogram the sensors?
Old Feb 21, 2007 | 01:45 PM
OleStraightStick
St. Jude Donor '08
thanks.. what are the easy remedies to start with? remove the wheel and visually inspect the sensor?
Old Feb 21, 2007 | 01:56 PM
wamara's Avatar
wamara
Nah, just retrain the sensor. I remember someone said deflating and then reinflating the tire might be helpful too - I don't know why or how, but I guess that can't hurt....
Old Feb 21, 2007 | 02:10 PM
NOWUCME's Avatar
NOWUCME
Yes, your right if he's not replacing the sensors just keep track of where the tires go.
The magnet i used was one of those mechanics magnets you can get in most auto parts stores. It's like one of those extension pointers with a small magnet on the end but its pretty powerful.
Old Feb 21, 2007 | 04:15 PM
Choreo's Avatar
Choreo
I posted this on a related thread yesterday where I was having trouble getting a magnet to work for reprogramming - tried 3 magnets. Finally I figured out (in my case) that I had to leave the magnet motionless for 5-seconds on each new sensor - then the horn confirmation sounded - that worked for me? Less than 5 seconds was not enough on mine for some reason?
Old Feb 25, 2007 | 12:01 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Hi All,
Thank you for the plug. I sell them all the time for the best price so if you're interested please contact me.
Thanks,
Gene
Old Feb 26, 2007 | 03:32 AM
Choreo's Avatar
Choreo
I got my set from Gene also and installed them with my new Michelins last week. Great price and service!
To Tire sensors
