After 6 days, battery is stone dead. Been cold here in PA, but ...in 6 days? Need a battery charge..what's the best? Some say the "battery tender plus". What say you? I want a very good one. This my first vette...first dead battery. HELP!!! and where do I purchase one?
If you want to charge it quickly - get a charger. A tender will generate 1-2 amps dependent upon setting and EVENTUALLY recharge the battery. The most convenient place to find chargers and tenders is Wal Mart - for 10-15 bucks you can get a tender made by Black and Decker that works fine. I have two in AZ and one in new Hampshire where batteries are kept happy for 6 months at a time. You can also get a combination quick start and charger for under $50. I don't have one, but my neighbor does and its pretty slick. It has an internal battery that makes it portable for starting remotely and he carries it on trips. He worries too much IMO. If your battery is not too flat, you can plug his unit into the cigarette lighter and get a start. If too far down, then you need to lift the hood and use the clips. I think it also acts as a tender, but am not sure - need to read the label.
There are tenders available cheaper - Harbor Freight has some for under $10, but I seldom get there and do get to Wal Mart for my $4 prescriptions.
The big question is whether it's the original AC Delco. If it is, change it now. The old batteries are prone to leaking and the computers are under the battery tray. Swap it out before you have big problems. AC Delcos don't like being discharged.
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Not to throw a negative into the mix. Just being stated as a precaution. If the battery is dead and it's below freezing the acid in the cells are sulfated and have turned to frozen water (ice). If you try to charge a frozen battery it could explode causing a lot of problems and possible injury. I would suggest if you're not going to replace it please take the time to thaw it out (maybe in the basement) then take it to a battery retailer to have it checked out for warped plates ETC before you charge it. Frozen lead acid batteries can be dangerous when handled badly. Ask me how I know.
If the battery is dead after 6 days even in the cold,, you need a new battery. I parked at the airport parking on business travel and never had an issue. Yours just propably doesn't retain the amperage to sustain over time given environmental and age. Jim
I don't know if a optima is the best. I DO know that you need a battery tender of some type. Go to wally world & get one that will keep a battery at full charge. You don't need an expensive one. When buying a battery, look for cold cranking amps. The higher=the better. There are only 3-4 manufactures who make batteries in the US. Optima is one but I have heard numerous people stating how they leak. That is a no-no on a C-5. since the computer sets right below the battery. (great design GM). Globe Union make most of the batteries you find at most wally worlds, sears, auto parts stores, ect. Delco make their own. Ford uses globe union along with Chrysler.(at least they did 12 years ago). Interstate is the only other manufacturer that I know of.
That is ABSOLUTLY the truth. Push on the side of the battery (if sealed) and if it has NO flex, take it out b-4 you try to charge it!
Dear Cole,
Do you know what the name of your friends charger/starter unit is or what brand. It sounds very versatile for many different situations. I'm currently having similar issues as my C5 sits outdoors and is mainly a weekend driver.
Thanks in advance for any info you can provide.
DH
Springfield, Virginia
I would appreciate knowing the same information. Will you please let me know? Thanks in advance....Ron
