Frame Savers
Old Feb 25, 2007 | 02:04 AM
Jeffyvette's Avatar
Jeffyvette
Default Frame Savers
There was a product I believe it was called a frame saver. It was a pair of wheels that were welded beside the frame horns and stuck down like a 1/2 past the frame so if you were going to touch down these would stop the frame from hitting. On lowered cars this is a great risk. Anyone have any info on these? i did a search and did not come up with much.
Thanks,
Jeffy'
Old Feb 25, 2007 | 02:08 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
http://forums.corvetteforum.com/show....php?t=1551916
Best on the market today
http://www.customcorvetteaccessories...fattdaddy.html
Peace
Chip
__________________
..................Click for
Old Feb 25, 2007 | 02:26 AM
DeeGee's Avatar
DeeGee
There are a few on the market. I got mine from A&A Corvette another Forum vendor.
The ones Chip sells which he's linked above look like a good product
You might want to consider rocker rails at the same time. These are reinforcement bars that run the length of the car and protect against grounding. Again a few of the Forum vendors including Elite Engineering sell them. these two mods are worth every penny in my view.
Old Feb 25, 2007 | 11:38 AM
MyOwn69's Avatar
MyOwn69
Old Feb 25, 2007 | 12:06 PM
FKING1's Avatar
FKING1
Originally Posted by MyOwn69
Old Feb 25, 2007 | 12:52 PM
Kale's Avatar
Kale
I'm curious how these differ from the $5.99 Casters found at hardware stores, that look identical to what vendors are selling.
Old Feb 25, 2007 | 08:26 PM
Look at the Fatdaddy's from Willfulone above.
Old Feb 25, 2007 | 10:27 PM
CCA Corvette Parts
Thanks Jack
310 shipped and only 1 returned
There are FattDaddys or FattMammas running the roads in every state except Alaska, Maine and Vermont
5 countries represented in the Fd or FM contingency, USA, Great Britten, Mexico, France and Argentina...
Peace
Chip
Old Feb 25, 2007 | 10:33 PM
04 torch red's Avatar
04 torch red
i made my own and they only cost $15. go to hd and buy there most heavy duty pair of castors and mount them. they look identical to the other ones and are a fraction of the cost.
Old Feb 25, 2007 | 11:49 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
:o here we go again
Old Feb 26, 2007 | 12:11 AM
CCA Corvette Parts
It's all about side load capacity, and static weight bearing capasity...
Researched it for 2 months with our engineers before we committed to a design...
Peace
Chip
Old Feb 26, 2007 | 10:41 AM
BitViper's Avatar
BitViper
Originally Posted by Yello95
:o here we go again
I thought aout doing the same thing...you cant find a wheel that will carry the load ( most of teh ones found in the HomeDepots etcc are only 75 lbs and pressed plastic...not gonna cut it for long) required for under 10 - 15 bucks a wheel...so buying from which ever sponsor is a steal.....
Im buying some today...
Old Feb 26, 2007 | 10:55 AM
Virtual Geezer's Avatar
Virtual Geezer
Also look at Willfulone's FatMamas!
Old Mar 11, 2007 | 11:48 PM
CCA Corvette Parts
My 10 yo son named the FattMamma and FattDaddy. Now he wants to name every product we put out
The next in the line of top secret products is called the "Black Max"
Named by my son ofcourse...
Peace
Chip
Old Mar 12, 2007 | 12:22 AM
rickko's Avatar
rickko
I put frame guards on. Installed them right at the bend in the frame horn.
Do they work? Yes and no.
Yes, if you are hitting a surface that isn't higher than the axle of small wheels.
No, if the surface/tire block/curb is a little higher than the wheels. In this case you still bang up against the object.
I'm not convinced they are completely worth the time, cost, and trouble to install 'em.
If I didn't already have them I'd certainly move them down to the bottom of my list of to-do-mods.
..rickko..
Old Mar 12, 2007 | 12:27 AM
CCA Corvette Parts
..rickko..
That's what these are for...
http://www.customcorvetteaccessories...skidplate.html
Peace
Chip
Old Mar 12, 2007 | 12:32 AM
rickko's Avatar
rickko
Thanks!
Didn't know of them. I think I'd rather have them than the wheels.
Thanks for the link too.
..rickko..
To Frame Savers
