Rolling back the mileage odometer
It only takes a few hours and a little technical savvy to swap the gauge cluster and if you did all of the maintenance yourself, the carfax would be empty. Even if the DMV reported mileage at inspection, what is stopping an undesirable from swapping the cluster before each inspection...
I wonder if that black box thing records mileage separately...
As I have learned from this forum's members and from a couple of Vette mechanics it is easy to alter the odometer reading in several ways.
I have used CarFax and AutoCheck as an imfornation source but certainly not the last word or a diffinitive resource , particulatly if the car is suspect by its condition. Example , I found a 1999 FRC in the LA, Ca area that had 48K , looked good and drove good. Carfax revealed 5 owners in 4 years plus a non descript lien in 2004 ( which could explain the 3 y/o repaint. The owner claimed not have any knowledge of the car's previous history. Very convienent I thought . I sent him a copy of the report after I returned home). He called to say he had no idea of the cars history but still was infactic that the car was good to him.
Thanks to everyone for their input on this subject.!!!
dD
Carfax has my mileage at each annual emissions check, but unless there is some annual state document about a vehicle, Carfax may be worthless.
As to CARFAX - should be called CARUNFAX.
There are way to many CARFAX reports that have been found to be incorrect. It is so easy to bypass these it is not funny.
Even if you have state inspections where they record the mileage - a $ or two to many inspection personnel will make sure that the mileage is what you want reported
If that doesn't work - in many states you can contest the mileage reported by the inspection stations - claim they wrote it down incorrectly - very few contest that.
If the vehicle is not serviced/repaired at the dealer - then there is little chance any information other than the date of sale will be in the CARUNFAX.
Even if the vehicle is serviced at the dealer - again a $ or two will many times result in a 'corrected' mileage report.
CARFAX has become a joke among used car dealers - like in the old days there are many ways of bypassing it
- however it is a GREAT tool for them to insist to the potential customer that this vehicle has never had an accident - always be serviced on time - etc. etc. etc.
Several carfax reports say one owner when there appears to be title changes. Other reports show several years of consistent data in an orderly fashion then suddenly the last few years are missing? I have also looked at cars that were in collisions or repainted and nothing on the car fax.
As a matter of fact I haven't seen a single carfax report that had anything bad to say. WTF? Judging by the number of C5s you can find at auction, something fishy is going on...
I guess you just need to get out the magnifying glass and put the car up on a lift. Check all the seams and pannel edges for repaint... thanks carfax
-AL
what you should do is ask where he has his oil serviced and check the mileage reports with them.
Up the lazy river to the big house. Roll back the odo,, and you will have a reason for a extenced stay with full medical coverage.
If I found and could prove it,, I would probably drop a dime on the subject
.Jim
But yes, it can be altered.
