Question about tires/ride
Old Feb 25, 2007 | 06:51 PM
SickSeries's Avatar
SickSeries
Default Question about tires/ride
I recently purchased a 99 Torch Red FRC. The car has about 37k on it and the tires are due for replacement as they have almost no tread left. Could the hard ride i'm experiencing be due to the treadless run flats, the Z-51 suspension, or a combination of both? I'm leaning towards replacing the tires w/ a non run-flat, something like a goodyear gs-d3, I've heard good things. My goal is a smoother ride, less road noise, without sacrificing too much performance. Any thoughts/suggestions?
Old Feb 25, 2007 | 07:11 PM
bcseitz's Avatar
bcseitz
GoodYear, Michlien, anything would be a huge improvment over bald EMT's !!!
You will think you had a new car!
Old Feb 25, 2007 | 07:18 PM
rgtkst's Avatar
rgtkst
especailly old dried up bald hard runflats. keep the tire pressures at 28-29 psi cold and it helps too. they warm up quick to the perfect pressure when you drive
Old Feb 25, 2007 | 07:29 PM
TheWolverine's Avatar
TheWolverine
The Goodyear GS D-3's get my vote. As Tony the Tiger says "The're GREAT!" I have a set on my C4, they will give you a smoother ride, less road noise, good tread wear, and fantastic traction on dry and wet pavement!
Old Feb 25, 2007 | 08:43 PM
Probably a combination of both the suspension and the tires as far as the stiff ride goes, but more of the tires IMO. Get a new set and I'd bet your ride improves significantly. The GS-D3s are an excellent choice.
Old Feb 25, 2007 | 08:47 PM
01yellowc5's Avatar
01yellowc5
From: Woodlake,The hill is without the king, California
St. Jude Donor '08
try nitto tires
Old Feb 25, 2007 | 08:51 PM
waunavet's Avatar
waunavet
St. Jude Donor '20
Got'em on my C5.
Old Feb 25, 2007 | 09:51 PM
Last C5's Avatar
Last C5
Or try the TOYO T1Rs for virtually the same tire as the GS-D3 and $300 less.
Old Feb 25, 2007 | 10:43 PM
Groucho's Avatar
Groucho
Default Hmmm....
Don't cheap out on tires...It's the only thing between you and the road, I find it interesting that some buy all these doo-dads then go cheap on tires..
Goodyear GS D-3's
Old Feb 25, 2007 | 10:47 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Any non-runflat is going to ride better than a set of used up EMT's.
I agree with the idea to not get cheap tires - you get what you pay for. The GS-D3 is a great choice as long as you aren't looking to upsize very much. If you're keeping the stock sizes the GY is a good choice.
The Z51 suspension does not make the ride harsh - it's definitely the tires.
Old Feb 26, 2007 | 02:22 PM
SickSeries's Avatar
SickSeries
Thanks for all the input. The tires aren't completely gone but they're getting close, maybe another thousand miles left. I think I will go w/ the GS D3s as most of you have suggested, hopefully I'll see major improvements. Thanks again!
Old Feb 26, 2007 | 06:34 PM
Groucho's Avatar
Groucho
Default Yep..
Good choice, you will think you have a new car!
Old Feb 26, 2007 | 06:56 PM
reindb's Avatar
reindb
I went from Goodyear EMT to Michelin Pilot Sport A/S and noticed a much smoother ride, especially on L.A.'s concrete freeways. However, just went down to 35's on the back (from 40's) and the lower profile is not as smooth. Still, better than run-flats!
Old Feb 26, 2007 | 08:28 PM
c5_alive's Avatar
c5_alive
St. Jude Donor '08
I like my BFG g-force t/a kdw, quiet, and great traction.
To Question about tires/ride
