My Battery went #@@#
Old Mar 7, 2007 | 09:35 PM
nfratto's Avatar
nfratto
I bought won thinking it was a good battery it leaked and died after one year. I don't reccomend
Old Mar 8, 2007 | 01:14 AM
moserbe's Avatar
moserbe
I let the battery connected while the car was in cold storage with temperatures below zero for a week or so. Found out the hard way that the security system drained the battery and it froze. Tried to recharge it but no go. I just bought an AC Delco Professional battery to put in it in a couple of weeks. My stupidity, but it won't happen again.
Old Mar 8, 2007 | 01:16 AM
moserbe's Avatar
moserbe
Originally Posted by LoneStarFRC
Pretty much true of most any automotive battery.
I agree!
Old Mar 8, 2007 | 05:40 AM
korte's Avatar
korte
Also if it is frozen, don't try to charge it or it will EXPLODE like a beer can in the freeeeezer!
Old Mar 8, 2007 | 09:41 PM
dwassenaar's Avatar
dwassenaar
Default Optima
Got my Red Top two years ago at Costco. No problems with mine--C5 sits for weeks at a time between uses.
Dave
Old Mar 8, 2007 | 10:10 PM
SSWEET's Avatar
SSWEET
Once you learn how to install your Optima Redtop...it will be a snap when you have to replace it every year with a new one!!!!!!
Old Mar 8, 2007 | 11:24 PM
TheWolverine's Avatar
TheWolverine
Three years with the Red Top, ZERO problems but, the winter home for my babies has heat.
Old Mar 9, 2007 | 08:47 AM
BRKLYN's Avatar
BRKLYN
Originally Posted by BiggieBoy
Why in the world do you want to do this????? This forum is loaded w/ thread after thread regarding premature cell failure w/ Optima batteries.... Do yourself a favor----buy anything but an Optima.....
So true. theres a lot of hype,on that optima battery.Seem's people alway's want to join the masses,wether good or bad.I've alway's replaced with wally world brand's.And never a problem.And very affordable.If you got's the bejamin's spend them.
Old Mar 9, 2007 | 08:59 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
After my OEM battery died in my '97 at the end of its usefull life, I put in an Optima Red Top and used it for 3 trouble free years of New England (winter included) and had zero problems with it.
Paul
Old Mar 9, 2007 | 09:26 AM
DADEO1's Avatar
DADEO1
Default Battery
I have a 99 and use the 78.
It should be the same for a 98.
Do yourself as favor and get a battery tender.
You will not have anymore problems.
And the Optima's are as good as any battery, maybe better because
they won't leak or as easy.
They have a free replacement if it fails within 36 months.
My first one without a battery tender failed at 35 months, got a free one
no problem.
Old Mar 9, 2007 | 09:41 AM
tramminc's Avatar
tramminc
1 What's wrong with a diehard battery?
2 What about uping the amps on the replacement?
3 Did anyone hook a 9 volt battery on the treminals before removing it to keep and your settings?
