California Emission option?
Old Mar 3, 2007 | 10:57 PM
Bracketman's Avatar
Bracketman
Default California Emission option?
Did a quick search on the internet and on the forums but didnt see anything about what the California Emissions option on the C5's did (or does), other than seeing it was a $170 option?
Does it change any way the car would normally operate?
Old Mar 4, 2007 | 12:43 AM
2KFRC5's Avatar
2KFRC5
On my 2000, CA Emissions (YF5), is listed as: No Charge. I'm not positive, but I believe it's the pup-cats in addition to the regular cats. Supposedly a 5hp loss, which was made up with a different cam for this year.
Old Mar 4, 2007 | 01:27 AM
87SAM's Avatar
87SAM
I’m thinking they are more or less the same. The YF5 means they may have had additional testing to confirm cleanliness for California. The code FE9 is a California/Northeast override option which may just mean less confirmation. The 5hp increase for 2001 was intake/cam. Not positive but I think pup cats went away after the arrival of the LT1 engine in 92.
Old Mar 4, 2007 | 01:39 AM
2KFRC5's Avatar
2KFRC5
My 2000 has pup-cats.
CAM SPECIFICATIONS
Part Number Valve Lift (in.,i/e) Duration (in., i/e) Lobe Separation Angle (degrees) Timing
1997 LS1 Y-car 12554710 .472 / .490 199 / 207 117 113 / 121
1998 LS1 Y-car 12554710 / 12560964* .472 / .490 199 / 207 117 113 / 121
1999 LS1 Y-car 12560964 .472 / .490 199 / 207 117 113 / 121
2000 LS1 Y-car 12560968 .500 / .500 198 / 209 115.5 112 / 119
2001 LS1 Y-car 12561721 .467 / .479 196 / 207 116 117 / 115
2002 LS1 Y-car 12561721 .467 / .479 196 / 207 116 117 / 115
2003 LS1 Y-car 12561721 .467 / .479 196 / 207 116 117 / 115
2001 LS6 Y-car 12560950 .525 / .525 204 / 211 116 114 / 118
2002 LS6 Y-car 12565308 .555 / .551 204 / 218 117.5 115 / 120
2003 LS6 Y-car 12565308 .555 / .551 204 / 218 117.5 115 / 120
Old Mar 4, 2007 | 01:42 AM
87SAM's Avatar
87SAM
CAM SPECIFICATIONS
I stand corrected
Old Mar 4, 2007 | 02:01 AM
DeeGee's Avatar
DeeGee
There's a new fact. I always thought the standard cats were compliant.
Old Mar 4, 2007 | 02:06 AM
2KFRC5's Avatar
2KFRC5
Again, not positive, but I think the pup-cats may have disappeared in 2001. Maybe someone with a California 2001 can confirm this, or not.
Old Mar 4, 2007 | 04:34 AM
87SAM's Avatar
87SAM
http://www.c5registry.com/2k2z06/page2.htm
Unable to copy from above site, but it states pup cats from 2000-2001 (Apparently some 99’s also). 2002 they went to two brick main cat. Some interesting info about half way down the page.
Old Mar 4, 2007 | 05:13 AM
skylark's Avatar
skylark
From the way California drivers are around here it is obvious that the California emmision package also came with the "turn signal delete option included" (free of charge of course)
Old Mar 4, 2007 | 10:34 AM
2KFRC5's Avatar
2KFRC5
Russ,
Skylark,
Old Mar 4, 2007 | 11:29 AM
Mike Mercury's Avatar
Mike Mercury
whoa !!!
2001 on.. all non-z06 C5's had pupcats (pre-cats).
earlier years... only some had the precats (depending on which part of the country the C5 was destined to be sold).
In 2001; the C5 became a "50 state car".. and all were made to comply with all 50 states "AlGore" requirements.
Old Mar 4, 2007 | 06:24 PM
Bracketman's Avatar
Bracketman
Thanks guys!
To California Emission option?
