Gear change
Old Mar 5, 2007 | 01:51 PM
IMGHST's Avatar
IMGHST
Default Gear change
For those of you who have replaced the gears, how did you adjust the speedo for the gear change and how simple was it?
Old Mar 5, 2007 | 02:20 PM
94legaleagle's Avatar
94legaleagle
Most swap the ENTIRE rear carrier, not just the gears - there are only a few shops in the US which can successfully swap the gears and not end up w/ a whining rear end
For those of us who swap the entire carrier and thereby put in a carrier w/ different gears, there is a speed sensor located on the top of each carrier that determines speed - it's basically plug and play - no need to recalibrate or adjust anything.
Old Mar 5, 2007 | 03:55 PM
IMGHST's Avatar
IMGHST
Do you know the speed sensor p/n for a 4.10 gear?
Old Mar 5, 2007 | 04:13 PM
LF97C5Vette's Avatar
LF97C5Vette
I had a DTE 4.10 pumpkin transplanted into my '97 C5 and there was no Speedo recalibration necessary.
You're gonna love you're 4.10s btw!!!
Dan
Old Mar 5, 2007 | 04:16 PM
Mike Mercury's Avatar
Mike Mercury
yep; no speedo error on a C5 when changing rear axle ratios.
Old Mar 5, 2007 | 05:16 PM
korte's Avatar
korte
If you put in any gears higher than 3.15 you will need to reprogram your computer for performance purposes.
Old Mar 5, 2007 | 06:07 PM
Vega$Vette's Avatar
Vega$Vette
Only on A4s no changes are needed on manuals.
Old Mar 5, 2007 | 08:40 PM
Mike Mercury
Only on A4s. no changes are needed on manuals.
Old Mar 7, 2007 | 07:30 AM
IMGHST's Avatar
IMGHST
Thanks for the input. I guess I 'm in luck....I have a manual
Old Mar 7, 2007 | 07:57 PM
korte's Avatar
korte
I got an AUTO!
Old Mar 7, 2007 | 09:06 PM
Vega$Vette's Avatar
Vega$Vette
Originally Posted by korte
I got an AUTO!
Me too! With 3:42s The reprogram is needed to set shift points up and down. Its not a bigb deal and a tuner should do it for about $150 max.
To Gear change
