How Hot?
Old Mar 5, 2007 | 04:02 PM
stormrider's Avatar
stormrider
Default How Hot?
How hot do C5 rotors get with heavy braking? I am trying to find a product to coat my slotted/dimpled rotors that not only looks good but will keep the hats, slots and dimples from rusting. I coated them with 3 coats VHT when they where brand new but they started rusting within a couple of months. If anyone has any product suggestions I am all
Thanks!
Old Mar 5, 2007 | 04:12 PM
doug doo wop's Avatar
doug doo wop
my Baer Eradispeeds are about 3 years old and no rust. I just polish the hats once inawhile and put a toothbrush to the slots to clean them.And the car sits outside year round, so it's probably the brand you have, sorry.
Old Mar 5, 2007 | 04:18 PM
rgtkst's Avatar
rgtkst
they do get hot.. mine are zinc coated. a very good quality hi temp 500+ degree paint will work fine. some of the stuff people use on the headers will not prevent rust. and if they have rust on them to begin with, it will rust under the paint eventually coming thru. good prep work goes a long way.
Old Mar 5, 2007 | 04:21 PM
jrose7004's Avatar
jrose7004
You need zinc dipped rotors.
Old Mar 5, 2007 | 04:39 PM
bkemp's Avatar
bkemp
Old Mar 5, 2007 | 04:42 PM
Oldvetter's Avatar
Oldvetter
You can use high heat (1200 F) paint on the rotor top hats and edges, I did. Don't worry about masking (except the caliper), the brake pads will clean off the braking surface. I used silver high heat rusteleom (sp?).
Old Mar 5, 2007 | 06:58 PM
stormrider's Avatar
stormrider
but I don't want to throw these rotors away with less than 5K on them so I am looking for a way to fix the problem
Old Mar 5, 2007 | 07:02 PM
AU N EGL's Avatar
AU N EGL
How hot? is this a trick question?
well 1400* and rotors glow orange
1600* even carbon rotors glow white
Dont coat your rotors with anything. For them to work properly the coating must come off anway. Even Zinc or that ultra-hard to get Urbermainium
To How Hot?
