Vert Wind Noise > 80mph
Old Mar 7, 2007 | 02:28 PM
sigma6's Avatar
sigma6
Default Vert Wind Noise > 80mph
I just adjusted the window tip in on my vert because there was some wind getting through and so now it's much quieter up until 80mph it soudns like the top is down because there's so much wind noise. I figure it's the rear of the window because this part along the vertical side of the window doesn't look like it full compresses against the rubber insulation. Is that normal? The top of the window itself looks pretty well pressed against the rubber.
Old Mar 7, 2007 | 04:33 PM
docbrew's Avatar
docbrew
This might help.
Vert top adjustment
Old Mar 8, 2007 | 12:46 PM
sigma6's Avatar
sigma6
Thanks, will try but can you guys give me some feedback on what speed do you start getting wind noise? Mine is pretty quiet up until about ~80mph. Is that what you're experiencing?
Old Mar 8, 2007 | 01:08 PM
02gt350's Avatar
02gt350
i have a coupe and at about 85 i hear lots of wind noise. At 150 its liek im in an air tunnel
Old Mar 8, 2007 | 02:27 PM
BATM4N's Avatar
BATM4N
I had this same exact problem when I first bought mine and returned it to the dealer for repair. The mechanic looked it up in his convette fix it book and it called for using double sided tape underneath the seal to make it "thicker" so the rubber seal will sit up against the glass. It worked. It doesn't take much of a gap between the glass and seal to get a lot of wind noise.
Come back and let us know if it works.
Old Mar 8, 2007 | 02:36 PM
sigma6's Avatar
sigma6
Good idea! I'll try that!
To Vert Wind Noise > 80mph
