stalling when put in reverse
Old Mar 8, 2007 | 12:07 PM
lbvett's Avatar
lbvett
2nd Gear
Default stalling when put in reverse
My girlfriend has a 2000 automatic, we live in the Boston area, I jump started the vehicle the other day because it had been sitting, when I went to put the vehicle in reverse it would stall, on the dash it stated something such as "service column lock"...any thoughts or comments of why or what this means....and why it may have stalled when put in reverse?
thank you in advance,
lbvett
Old Mar 8, 2007 | 12:12 PM
VetteBandit's Avatar
VetteBandit
You have the service column lock problem. There are lots of posts on how to get it fixed. Its a warranty issue, that can be corrected a few different ways. Do a search, or look in the stickys section of the C5Tech forum. There should be a post about different methods to solve this issue.
Old Mar 8, 2007 | 12:13 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
the computer thought you were trying to steal the car, so it shut off the fuel. If you look at this post - http://forums.corvetteforum.com/show....php?t=1015483
it will tell you all about this problem, and the potential solutions.
Hope this helps....
Old Mar 8, 2007 | 12:53 PM
M6 Vetter's Avatar
M6 Vetter
Buy a Colum Lock Bypass kit
Old Mar 8, 2007 | 01:02 PM
Humy's Avatar
Humy
To stalling when put in reverse
