'00 C5 air press sensor calibrate?
Old Mar 8, 2007 | 08:06 PM
C5-Attitude's Avatar
C5-Attitude
3rd Gear
Default '00 C5 air press sensor calibrate?
Can I go into a program in the DIC and reprogram the air sensor right to left. The tire store switched my rear sensors. Gm guy said I could get into the program and put a speaker magnet buy the sensor and the car will since it. Is this only on the '01-04 or is there a procedure to do it on my '00 I can't seem to get into? Thanks, I tried a search on the subject and did not get much. Later>>>>>>>>>>>>
Old Mar 8, 2007 | 08:15 PM
JTE's Avatar
JTE
CI 4-7, 9 & 10 Veteran
https://www.corvetteforum.com/techti...D=77&TopicID=1
Old Mar 8, 2007 | 08:19 PM
TopFuelTim's Avatar
TopFuelTim
Default No problem
Used this to reprogram my new sensors. Very easy.
Old Mar 8, 2007 | 08:39 PM
C5-Attitude
3rd Gear
Default Thanks!!!!
Thanks for the quick reply. You guys are awesome! I'll be on it first thing in the morning. Later>>>>>>>>>>>>
Old Mar 9, 2007 | 12:40 AM
Shouldn't take you more than 5 minutes to do it using the above instructions.
To '00 C5 air press sensor calibrate?
