Driver Window wont go up!!!!!!!!
Old Mar 9, 2007 | 09:07 PM
darkriderzx10's Avatar
darkriderzx10
Default Driver Window wont go up!!!!!!!!
I have a 98 vette and I rolled my drivers window down today and it would not go back up. It goes up about an inch and it will not go any further. Could this be a possible window regulator problem or is it something i could fix. I could the motor working and it moves the window about an inch up. Your help will be greatly appreciated..
Old Mar 9, 2007 | 10:40 PM
NetBob928's Avatar
NetBob928
I just went through a passenger window issue. It sounds like the regulator but your best bet is to pop the door panel, pull the rubber cover, and take a look. Instructions to pull the panel are here and here
Old Mar 9, 2007 | 11:01 PM
z06Bigbird's Avatar
z06Bigbird
Retail price could be as high as $600, but you, with the advice of other members, could likely fix it for about $75??
Be careful window does not slam down and chop off your arm or hand.
(Typical of many power window units, GM, Ford, etc.)
To Driver Window wont go up!!!!!!!!
