PIAA 1100X Install
Old Mar 10, 2007 | 09:41 AM
pjbracing's Avatar
pjbracing
Default PIAA 1100X Install
I am replacing my stock fog lights on by '03 Vert with the PIAA driving lights. I want to use as much stock wiring as possible and of course the kit comes with a whole new harness, relay and button.
Question 1: At what point can I tie in my stock wiring, dashboard switch and relay to the PIAA harness?
Question 2: Can I just cut the PIAA harness where the actual lights are installed and tap into the stock wires?
Thanks for the advice!
Pete
Old Mar 10, 2007 | 09:42 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Pete, no you cannot use the stock wiring but you can use your existing factory Fog Light Switch
https://www.corvetteforum.com/techti...=130&TopicID=1
Old Mar 10, 2007 | 10:36 PM
pjbracing's Avatar
pjbracing
Thanks - followed the instructions you referenced and they work great. I need to aim them a little lower, but what a difference!
Pete
Old Mar 10, 2007 | 10:40 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Congrats!
Very cool
Old Mar 11, 2007 | 09:21 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
I see the link EG gave and it says for Z06's and/or FRCs, to tie into the purple wirer under the fuse box.
If you go by those instructions given, will the piaa's come on with high beams or are they seperate, as you turn them on when you want and off. (Been so long in the garage I cant remember how they work with the stock fogs )
I want to hook them up using the the stock fog light switch and be able to turn on/off when I desire.
Thanks for any and all help.
Old Mar 11, 2007 | 09:32 PM
FactoryRaceCar's Avatar
FactoryRaceCar
Congrats!
Old Mar 11, 2007 | 09:45 PM
0EG@EnglandGreen
Supporting Tuner
Like your stock fog lights, they will switch OFF with your high beam. They are actuated via the fog light switch and will work with the park lights or low beams. I normally just drive around with just the PIAAs and leave the barn doors closed.
Old Mar 11, 2007 | 09:52 PM
FactoryRaceCar
Here is how PIAA 1100X look like with 6k HIDs on SW C5R with projectors
To PIAA 1100X Install
