The key....
Old Mar 11, 2007 | 01:08 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Default The key....
Why does my Corvette key have a chevy logo on it? Why not the corvette cross flags like the rest of the car ?
Old Mar 11, 2007 | 01:16 PM
moserbe's Avatar
moserbe
That way Chevy could use the same key for multiple vehicles.
Old Mar 11, 2007 | 01:56 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
The lone exception was the 2003 cars - they had a 50th Anniversary logo on the key. If you are that intent on having one of those for your car - you can order the key blanks from Ecklers or any of the other catalog houses.
All you would have to do is determine which VATS chip is on your key - and that can be done by using a digital volt meter, and reading the impedence in ohms - and then referring to this chart -
VATS key codes
You need to read the resistance of the key. If you have a digital volt meter, set it on ohms mode and measure the resistance of the pellet on your key. The BCM is programmed for a specific resistance value. The BCM measures the voltage drop across the key pellet. If it is within +/-10%, then the car will start.
The 15 resistor codes are:
Key# Value (Ohms)
1 392
2 523
3 681
4 887
5 1130
6 1470
7 1870
8 2370
9 3010
10 3740
11 4750
12 6040
13 7500
14 9530
15 11800
Once you order the right key and receive it - all you need is a locksmith that can cut a double sided key, and you have a key with a Corvette logo on it. Pretty simple. Hope this helps!
Old Mar 11, 2007 | 02:16 PM
SSWEET's Avatar
SSWEET
After all..... they are Chevrolets............
Old Mar 11, 2007 | 03:19 PM
jrose7004's Avatar
jrose7004
Another example of an off the shelf item to keep the cost down.
Old Mar 11, 2007 | 08:55 PM
silverbullit99's Avatar
silverbullit99
It is a chevy after all.. Get a nice C5 keychain,, that's what I did ..
Old Mar 11, 2007 | 09:49 PM
korte's Avatar
korte
pennywise and dollar foolish GM!
but look on the bright side, no one knows its the keys for a corvette so they'll have less chance of stealin' em!
Old Mar 11, 2007 | 09:59 PM
Corvette-Chris
St. Jude Donor '08
Good thinkin ^
Old Mar 12, 2007 | 02:56 AM
Bill Dearborn's Avatar
Bill Dearborn
May not be really off the shelf. None of my other Chevy or GM products have the same length key.
Bill
Old Mar 12, 2007 | 11:23 AM
SPIVET's Avatar
SPIVET
Bill
OK, Let's not go there...
Old Mar 12, 2007 | 11:28 AM
skidmarc's Avatar
skidmarc
I saw in Eckler's catalog they have a flip out key/fob for Corvettes for $99. Looks pretty cool but I just paid $50 for a new FOB as it is. I wonder if anyone else has em cheaper. I remember a while back someone was custom making them on the forum and selling them.
Old Mar 12, 2007 | 12:10 PM
Bracketman's Avatar
Bracketman
That doesnt bother me all that much, since the keys are mass produced for other automobiles.
However, I like the fact that the car itself has many references to the Corvette (steering wheel, passenger dash, seats, etc) unlike the 99 T/A I owned which had a single pontiac badge on the steering wheel. I always thought that the T/A was the "over the top" car in terms of decals and whatnot, but I guess that changed in the 90's.
Old Mar 12, 2007 | 12:17 PM
B-rent's Avatar
B-rent
I like them too, imma get one some day
http://www.ecklers.com/product.asp?p...dept%5Fid=1722
Old Mar 12, 2007 | 12:57 PM
C5 ChemE's Avatar
C5 ChemE
I like the steath-ness of the key... wouldn't know it's for a Vette... except for the shiny cross-flags key chain and "REMOVE BEFORE FLIGHT" tag hanging off it!
Old Mar 12, 2007 | 05:44 PM
korte's Avatar
korte
My key is VERY long..
To The key....
