How do you launch a C5 A4 ??
Old Mar 14, 2007 | 06:12 PM
George Hubert's Avatar
George Hubert
Default How do you launch a C5 A4 ??
I have the urge to run a 1/4 mile on a drag strip. I have no idea how to "launch" the vehicle. Is there a procedure to get the best launch? I guess I could just put it in 3 and put the pedal down till the lights flash. but is there a way to get off the line faster???
Old Mar 14, 2007 | 06:27 PM
Bracketman's Avatar
Bracketman
Thats a good question, I'd like to see what others think!
Old Mar 14, 2007 | 06:29 PM
JEEP/C5's Avatar
JEEP/C5
I never raced mine, but I have seen the question posted before. Try a search for this. I would put mine in 3rd and put her in competiton mode if I were to race. Many will do a burn out to put heat in the tires - make it hook up better. Good luck.
Mike Mercury's Avatar
Mike Mercury
with street tires and a stock C5... drive around the water box (instead of through it); no need to warm up street tires.
place shifter in 3
turn off Traction control (use competitive mode for those that have it)
powerbrake on the starting line to around 1300-1400 rpm; that's all you'll probably be able to get with a stock converter.
release the brake on the 3rd yellow as you push the accelerator all the way to the floor. Don't mash the accelerator, as it might just light up the tires. As I release the brake, by the time I say "a thousand one"... that's the rate I push the accelerator to the floor.
complete mod list:
3.42 rear axle (stock converter)
Z06 air box lid
Oiled OEM style K&N drop-in air filter
gutted pre-cats; but main cats untouched.
Predator tune
factory tires
Old Mar 14, 2007 | 06:41 PM
zeevette's Avatar
zeevette
They call automatics "stab and steer" for a good reason.
Old Mar 14, 2007 | 07:22 PM
George Hubert
Default launch
complete mod list:
Z06 air box lid
gutted pre-cats
Predator tune
factory tires
THanks Mike, thats exactly what I was wanting to know, any other opnions??
Old Mar 14, 2007 | 08:12 PM
Patman's Avatar
Patman
I've tried powerbraking at various rpms but it never works as well as just mashing the pedal right to the floor right off idle. I've gotten my best 60fts with that method.
Old Mar 14, 2007 | 10:47 PM
1965imp's Avatar
1965imp
Leave the traction control on ( you don't want any wheel hop ) Leave it in "D" and slam the peddle to the floor from idle on the last yellow.
Old Mar 14, 2007 | 10:52 PM
tiojames's Avatar
tiojames
You do need to warm up street tires as they are a harder material than drag tires. Tony Pedregon(funny car pilot) answered that question in the last issue of Hot Rod. He said that the top fuel and funny car tires are so soft now the burn outs they do are to put heat in the engines, not the tires. The tires will stick better if they are warm. Same deal as driving on a warm road or a cold one.
Old Mar 15, 2007 | 01:12 AM
Grayeagle's Avatar
Grayeagle
Bracket raced for almost 2 decades .. most of it with automatic car.
Just startin with the auto-C5 I have now .. I did 3 passes to check out what works with my C5.
Runflats suck.. regardless of what you do to launch the car
If you get up on the converter at all, you will hook a little better because you reduce the converter 'flash' shock reducing the torque applied at launch. Do this if you have major traction issues.
If you run somethin sticky in back, just punch it off an idle .. you will get all the converter can give you for a launch.
If you run a cam with a lot of overlap, you will need a bit of rpm to launch at ... 3k or so converter is the ticket to let the motor be into the cam a bit before it locks up and launches the car
As far as burnouts .. street tires dont need 'em. You can burn 'em the length of the track an they are still gonna hook just the same as you just cleanin em off.
Slicks need to get hot to hook best, you can tell they're 'right' when they start pushin the car outta the water
-Frank
Old Mar 15, 2007 | 01:27 AM
inoyourtrippn's Avatar
inoyourtrippn
complete mod list:
Z06 air box lid
gutted pre-cats
Predator tune
factory tires
BUT.. i turn the t/c off and i start out in 1st and work it up. plus i drop the tire press too
but i would try your own way til you find what best for you
Old Mar 15, 2007 | 07:09 AM
VET IT B's Avatar
VET IT B
Mikes way will work. PRACTICE is the key. I have 315 gears, you can not smash the gas. I have had some luck with putting her in first gear off the line and slide her to second when I know I am hooked. Mark
Old Mar 15, 2007 | 09:38 AM
chaase's Avatar
chaase
St. Jude Donor '12
This is coming from someone who has put more than a few passes on an A4.
1) Put the car in "3" (nothing else -- you will not be able to manually shift it properly, these shifters stink)
2) Go into competition mode -- no wheel hop with runflats you just burn up the tires
3) Go around the water box, but do warm up the tires.. It does help the runflats are very hard tires tires so warming them up helps a little -- and its fun. (I experimented with both and decided this was best)
4) Get the RPM up to just over idle -- around 1100rpm
5) On the third yellow lay into the pedal. I have gotten 1.9xx 60' times on run flats with that method
That is all you need to do.
The only differences between a pass in ruflats vs drag radials is that I turn comp mode off and I go through the water box.
Old Mar 15, 2007 | 09:45 AM
Mike Mercury
ya know... I did leave out those two steps;
*place A4 in 3
* turn off TC but leave AH active on (if your C5 has the competitive mode)
I will edit my earlier post.
I totally disagree with leaving TC active . In theory this sounds good, but the C5 TC is not optimized for racing applications. It`s an ice/snow traction system.
Old Mar 15, 2007 | 09:58 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Turn off the traction control!
Do not try to heat your tires up!
Do not go through the water box! (You'll also have water on the front tires and on launch you'll drive right through the front tire water!)
Get up to the light and stage the Vette (two top yellow lights will light up) STOP!
Put one foot on brake and one on the accelerator pedal and bring the RPM's up to about 1700
Watch the tree and on the THIRD yellow stab the accelerator(By the time you move you will have a GREEN light and will not RED light)
You'll cut a good reaction time this way!
Run the vette WOT all they way to the end and then collect your time slip at the booth and BE SAFE! and Have FUN!
Thanks,Matt
Old Mar 15, 2007 | 10:00 AM
Jim2003's Avatar
Jim2003
I have a mn6 vette and have not been to the strip. But I raced my 87 Buick GN often.
I never went through the water. I have heard over and over to not go in the water with street tires.
I never heated the tires, but I did not have runflats.
I did do the break torque.
I did smack the accelerator rather than squeeze it. I got some wheel spin. With the GN that helped bring up the turbo quicker. I turned in the 14.4 and 96 mph with 80k on the car.
Old Mar 15, 2007 | 10:27 AM
lytspeed1's Avatar
lytspeed1
Goes without saying.....but make sure you turn off the A/C as well..!!!!!...
To How do you launch a C5 A4 ??
Old Mar 15, 2007 | 12:20 PM
Humy's Avatar
Humy
I know what I am going to be doing at lunch today
Old Mar 15, 2007 | 12:24 PM
Humy's Avatar
Humy
with 3.42s and a 2800 stall TC, Nitto 555s and common bolt ons, what rpms should I hold it at?
how much tire spin can I expect off the line, after I let go of the brake (assuming they are aleady spinning before I let off the brake)
Old Mar 15, 2007 | 02:34 PM
chaase's Avatar
chaase
St. Jude Donor '12
Very similar setup to mine, except I use the Mickey Thompson DR's. I get little to no tire spin off the line launching below 1500rpm.
