"Service Active Handling" on DIC
Old Mar 17, 2007 | 12:40 PM
rons99's Avatar
rons99
Active Streak: 90 Days
Originally Posted by rgtkst
you know.. when you read the title to this thread its kinda funny sounding!!!!! says "service, active handling" on DIC
ok--- it sounded funny
sounds like ya figured it out. my dic said that one time too !!!
I was going to say "my DIC" but decided against it. Wouldn't that get it moved to PR&C?
Old Mar 17, 2007 | 05:57 PM
DeeGee's Avatar
DeeGee
Sounds like a dodgy explanation
Ask them which module they replaced in case it doesn't fix it. There are 3 main elements that could be bad. If they think speed is an issue I'd be asking more questions!
They'll probably replace the EBCM.
Old Mar 18, 2007 | 02:20 PM
crtaylor1's Avatar
crtaylor1
From: "Officer, are you sure I was going that fast?" Texas
I had the same problem, and it was the steering wheel sensor.
Old Mar 18, 2007 | 07:35 PM
Blue Lion's Avatar
Blue Lion
I had this message recently, followed by "service abs". They went away after a day. Then the serpentine belt started squeaking. Then the "service engine soon" light came on. Then the serpentine belt let loose. Now I have a new tensioner and belt.
I assume this fixed the problem but it's too early to tell.
