That's interesting. I use Valvoline Synpower in my clutch reservoir and it doesn't leach to black at all. The fluid in the syringe in your picture looks horrible. I've never even been close to fluid that dirty.
I don't use the ATE SuperBlue because over time it stains the reservoir. I know it's popular to use the Blue then on the next brake flush use Gold so you can see when you're completely flushed. I don't do that. I was using Motul RBF600 in brakes and clutch but it has a caramel color and is hard to tell when it is dirty in the clutch. Easy to tell when you cook it on track and bleed some off the calipers.
I do about 8 HPDE(s)/year and my clutch fluid never looks nasty after an event. Just a little darker and there is a bit of dark crap in the bottom of the reservoir. Suck it all out and wipe clean and refill. So far I have no clutch problems.
ATE makes an amber fluid as well called type 200. (This fluid does not stain like the blue) It is clear going in and turns dark with age/use. Good stuff so far. I have been using it for over a year now with great results. You can get it at PFYC. Don
Thanks you again for your input. I jsut got time to read it. Well nice to see I'm not alone on this issue. I guess I will give the prestone DOT4 a try next.
So far I've done two iterations of the method using Prestone DOT3 Brake Fluid. First time I opened the lid to check it out it was definitely black with a few granules built up on the rubber condom looking seal. Car had 19425 miles on it.
I changed it using a syringe and a funnel. After about 10 days I changed it again using the method. I would estimate that it was 70% clear, changed at 19500 miles.
I checked it tonight (about 6 days since last change), and now it is about 90-95% clear, car is now at 19550 miles.
Seems to be working great, I'm just wondering how long on average it takes to start seeing the murkiness build up again. I'm going to leave it alone now until I see it get down to 75% clarity or so.
Kind of odd seeing it this clear, this fast, knowing that I haven't cycled out the entire amount of fluid yet isn't it? By the way how many changes does it take to do a complete cycle-flush? I estimate that I'm adding about 1.5-2.0 ounces of DOT3 each change, putting it right where the rubber condom displaces the fluid to max without overflowing the reservoir.
...Seems to be working great, I'm just wondering how long on average it takes to start seeing the murkiness build up again. I'm going to leave it alone now until I see it get down to 75% clarity or so.
Desert, what you want to do is change the fluid in the reservoir; replace the cap; then pump the clutch pedal 10-20 times; and then inspect the fluid. Pumping the pedal causes flow within the closed hydraulic system and will express the fluid that's down in the slave.
Regarding the fill line, you can feel the line with your finger inside the reservoir. You want to fill just up to that line.
i'm about to do this too... changing brake and clutch fluid. i thought i read somewhere that this condom thing had to be collapsed into the screw-on cap to the reservoir before replacing the cap. i'm a dummy and not sure exactly what this rubber piece does. ive seen them in brake fluid reservoirs too.
^^^ The rubber fitting is intended to reduce abrupt changes in (e.g. buffer) available volume for the closed hydraulic system during abrupt transitory movements by the car. Examples are strong shifts or high G-force turns.
Yes, the rubber fitting is supposed to be collapsed inward before the cap is replaced.
Ranger
Yeah I tried this yesterday but to no avail. I'm not worried about it, in the manual they have a picture of it being taken out or put in un-collapsed, or open.
