Do C5's Have a Rev Limiter??
Old Mar 19, 2007 | 02:51 PM
B-ras's Avatar
B-ras
Originally Posted by Zilla
the Z06 is set a little higher than the vert or coupe. I believe that the rev limter can be change used one of the programmers.
The LS6 is set at 6700, 200 above the red line, just like the LS1.
Old Mar 19, 2007 | 03:00 PM
VERTC5's Avatar
VERTC5
Originally Posted by BowTieRocket
The way the limiter works is a fuel cut-off set at 6200. Same concept in most FI cars (and bikes - my 2003 Harley has the limiter, set at 5500). When you hit it, the fuel is cut off and the car feels like it's missing.
Does it actually cut the fuel off or just let off the throttle a bit? It's fly by wire and it seems that cutting the fuel off would be unecessary.
Old Mar 19, 2007 | 03:22 PM
BaneZ06's Avatar
BaneZ06
Supremacy 1 car at a time
If you miss shift into neutral youll be fine, if you miss shift back into a lower gear is when it will hurt you. And rev limiter doesnt set any codes btw
Rev limiter in my Z
Old Mar 19, 2007 | 03:32 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Originally Posted by RatedX
England Green fixed my rev limitations!
(among other annoying "tuneless" problems)
Old Mar 19, 2007 | 03:36 PM
slpippen's Avatar
slpippen
Yes it does. I've hit it once and my husband did a year earlier. Scared the begezess out of both of us! You can hear it and feel it.
Old Mar 19, 2007 | 04:23 PM
jfrc's Avatar
jfrc
yeah, i bang it once in awhile autoXin
Old Mar 19, 2007 | 05:44 PM
DAVS Y2K's Avatar
DAVS Y2K
Banned Scam/Spammer
Mine has a rev limiter and a speed limiter. But luckily it's detachable.............................. ....I leave the wife at home 99% of the time.
Old Mar 19, 2007 | 07:30 PM
fdxpilot's Avatar
fdxpilot
Originally Posted by wedieyoung1
a friend of mine told me that the computer had two connectors on it. one for economy(speed limiter) and one without. he said gm put it in so people couldn't out run the cops but all you have to do is plug in the other connector. told him i had my 99 coupe up to 140. he says it's there though. anyone hear of this?
Your friend is full of it. There is only the above mentioned RPM limiter. There is no speed limiter. The limit is aerodynamic drag at around 175 on a stock car. Increase the HP and you can go faster. To go a lot faster, you need a lot more HP, as power required goes up with the cube of velocity. The 06-07 Z06 with the same gearing can only get to 198 with 505hp.
That's not a speed limiter. It's a aural speed warning. I frequently have it on my vette, also.
Old Mar 19, 2007 | 07:57 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Originally Posted by Glennm27
Many times when you hit the limiter hard (like you did) your car will throw these codes, P0171 & P0174 and those codes WILL turn the Check Engine light on......
Originally Posted by get0mod
what do those codes stand for?
They mean you have leaned out the engine.
There is a code thrown for each bank (each side) of the engine.
P0171 - Fuel Trim System Lean Bank 1
P0174 - Fuel Trim System Lean Bank 2
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Your friend should stick with things he knows something about. This ain't one of em.
Old Mar 19, 2007 | 07:59 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Yes they do and it can be changed using a handheld programmer!
Thanks,Matt
Old Mar 19, 2007 | 08:28 PM
Yes, they have a rev limiter. I've hit mine a few times.
Old Mar 20, 2007 | 04:28 PM
  #33
get0mod's Avatar
get0mod
Thanks Glenn
Old Mar 20, 2007 | 04:36 PM
  #34
FactoryRaceCar's Avatar
FactoryRaceCar
Rev limiter in my Z
Old Mar 20, 2007 | 04:51 PM
  #35
Johnny Hardcore's Avatar
Johnny Hardcore
CLASSIC!!!!
I blew my push rods on my '99 coupe twice, when it was stock, due to pushing the car too hard. I over revved the car and POP...POP...BANG!
I was fortunate enough to have a freind in the service department at Chevy and they covered the repairs under warranty, both times.
I then had the heads, cam and tune done in the car and now it makes power up to 6900 rpm's.
I shift at 6750, tp stay on the safe side. The car runs very strong, getting those extra RPM's made the car feel like a brand new car once the tune and sdjustments were made.
The stock stuff just isnt made to take that type of a beaten, the rev limiter will only save you some of the time.
Old Mar 20, 2007 | 05:43 PM
  #36
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Would you like to place a bet on that?
The speed limiter in the PCM is factory set at 255mph.
Old Mar 20, 2007 | 07:23 PM
  #37
c5_alive's Avatar
c5_alive
St. Jude Donor '08
P0171= Fuel trim system lean bank 1
P0174= Fuel trim system lean bank 2
http://www.stengel.net/diccodes.htm
To Do C5's Have a Rev Limiter??
Old Mar 20, 2007 | 10:18 PM
  #38
fdxpilot's Avatar
fdxpilot
Well, no limiter of any consequence. If you run up against that limit, you're a better man than me, Charlie Brown. It's not like on early 90s F-bodies, where if you didn't buy the Z-rated tires, the PCM limited you to 108mph.
Old Mar 21, 2007 | 02:18 PM
  #39
wedieyoung1's Avatar
wedieyoung1
Default hey
the funny thing about my friend is he's a mechanic. he's been doing it all his life. i'm razzing him for this one.
Old Mar 21, 2007 | 03:12 PM
  #40
Black C5 Z06's Avatar
Black C5 Z06
Depends on the gear.
1-4 & 6 is a hard fuel cutoff
5th is gradual so it feels like your maxing out against the air resistance. Actually, whoever said that the only speed limiter is air resistance is full of it. The Z06 can go faster than stock if you only raise the rev limiter in 5th gear 200-500 rpm.
Cheers!
