What does this code mean? "Remove Key and wait ten seconds"
Old Mar 19, 2007 | 03:28 PM
BarryBum's Avatar
BarryBum
St. Jude Donor '10
Default What does this code mean? "Remove Key and wait ten seconds"
Mine has done that twice in about 2 months, what does that mean?
Old Mar 19, 2007 | 03:37 PM
Freddy_97_C5's Avatar
Freddy_97_C5
Default MINE TOO after recall
I got the same message after I picked it up from dealr for doing the recall on steering lock and replacing throttle position sensor.
After, i tried to drive off with message car just immediately shut off so, I did what it said and it seems to give me warning almost all the time.
The stealership said, I had a "POSSIBLE" bad ignition switch this was after I took it back the second time. I am not to sure they know what they are doing.
Old Mar 19, 2007 | 03:38 PM
OUR97's Avatar
OUR97
Remove the key and clean off the resistor on it. Try again and it should be fine.
Old Mar 19, 2007 | 03:39 PM
02gt350's Avatar
02gt350
Column lock bypass.......search it. you will see endless info on it
Old Mar 19, 2007 | 03:45 PM
OUR97's Avatar
OUR97
I got the 10 second display even after installing the clb. Most forum members will agree to a dirty resistor on the key. It wouldn't hurt to get a clb anyway.
Old Mar 19, 2007 | 06:35 PM
stormrider's Avatar
stormrider
I got that message when my starter was starting to go bad
Old Mar 19, 2007 | 07:55 PM
65GGvert's Avatar
65GGvert
Update your profile from 93 polo green to current and you can get more help on the issue.
Old Mar 19, 2007 | 08:06 PM
Bakersfield's Avatar
Bakersfield
I had that on my 98 and no more problems after the factory recall was done. Make sure they replace the K-Harness device. Good luck...
Old Mar 19, 2007 | 08:09 PM
BarryBum's Avatar
BarryBum
St. Jude Donor '10
I took it by the dealership today to have the VIN run. The column lock was fixed in 05. He told me to clean the resistors on my key with alcohol and that would more than likely fix the problem.
Old Mar 19, 2007 | 08:15 PM
Bakersfield
Yes, cleaning the key might fix it, but my car also had the recall done before I bought it, but it wasn't done correctly. My dealer did the recall again and charged back the original dealer for their blunder. If the wheel locks after you remove the key, then the recall was not done properly. Hope this helps....
Old Mar 19, 2007 | 08:19 PM
Old Mar 20, 2007 | 01:28 AM
skylark's Avatar
skylark
I guess I will start having to clean my ears with my truck key to keep this from happening
Old Mar 25, 2007 | 02:06 AM
yaknow's Avatar
yaknow
Install CLB or go down the road of being victumized by something you can resolve yourself.
Old Mar 25, 2007 | 02:13 AM
DeeGee's Avatar
DeeGee
It could be the key but way more likely to be the column lock even if all the recalls have been done. We read so many problems even after the latest GM "no-fix".
Get a CLB. $50 and a few minutes to fit and you'll be rid of the problem for good.
Old Mar 25, 2007 | 02:35 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Old Mar 25, 2007 | 06:26 AM
JeepTJ's Avatar
JeepTJ
Another
Old Mar 25, 2007 | 07:12 AM
Frozenfire's Avatar
Frozenfire
I had a similar problem with a dirty resistor contact. However the SECURITY light came on and the car wouldn't start. I didn't get the WAIT 10 SECONDS message. I just cleaned the resistor tabs a little and that fixed the problem.
Old Mar 25, 2007 | 07:38 AM
scooter94mp's Avatar
scooter94mp
I had the same issue when my column lock refused to disengage. I got the lock to disengage and installed the CLB and I have yet to see the message again. Just my experience / $0.02
Old Mar 25, 2007 | 04:49 PM
OzzyC4's Avatar
OzzyC4
like others have said, wash the keys resistor pellet with some rubbing alcohol, and while you are at it CAREFULLY clean the corresponding contact points in the ignition switch with the corner of a cloth dampened with the alcohol.
To What does this code mean? "Remove Key and wait ten seconds"
