Good luck on this one. I've found that revving to about 2.5k and slipping it fast (DONT DROP IT) and going easy on first (like half to 3/4 throttle) then mashing it on second should give you 2.0ish kind of 60 foots. good luck!
I am in no way, shape or form in the same range as Ranger, Rob Z, Dr. Ron, MSG Huff ect... but the tecnicues in the above post work. Print them out and read them in the staging lanes, and visualize it. Practice, and get as much seat time as you can. A stock Z will dip into the 11s with a great driver, but most of us, are happy in the 12s bone stock. You will find that when you figure out the launchm your times will drop more then HP mods
Dave
PS let us know how it goes brother
