Shock Replacement....?
Old Mar 24, 2007 | 01:40 PM
LF97C5Vette's Avatar
LF97C5Vette
Originally Posted by Black 'n Tan
I agree those C-6 Z06 shocks are a pain in the *** to put in the rear end, they are freakin crazy stiff. I removed the rear tie rod end and slighly rotated the spindle to lower the arm, and clear the CV boot.
John
Weird - i just did the C5Z06 Sways and C6Z06 shocks, and i had my 300lb friend compress the rears and use mondo zip ties to hold 'em down. Once we zip tied them, they were Really easy to install - just slipped them around the control arms and tie rod, lined them up - then cut the zip ties... Cake! :-)
To the OP, like i said I just installed 04 Z06 Sways and 06/07 Z06 Shocks replacing my Factory F45 (Select Ride) suspension. On KDW2s, this setup is amazing. Vastly superior to the factory ride... And very affordable! I picked up the sways slightly used for $210, and the Shocks bran new for about $215 (Gene Culley)
This afternoon i'm driving to a dealer ship to use a Tech II to remove the Factory F45 option from the BCM.
Dan
Old Mar 24, 2007 | 02:50 PM
LLVETTE's Avatar
LLVETTE
Originally Posted by Brad@thecorvetteshow
In your center console you should have a three position switch, if its there you have the selective ride control.
As stated earlier, you can go to ratshack and get four 10 watt 10 ohm resistors and solder them in and it does the same thing for 10 bucks.
Brad
OK Brad, excuse my ignorance...I am dumping the F45 shocks and going to Bilsteins. I assume that this fix is for the error code? Where do the resistors get soldered to?
Thanks, Greg
Old Mar 24, 2007 | 03:59 PM
berryj's Avatar
berryj
Brad
Brad, my car doesn't have a 3 position switch. So I can safely assume I don't have the F45, right? If I don't have it, then I can just upgrade to even the C6 Z06 shocks and sways without any reprogramming issues?
Old Mar 24, 2007 | 04:56 PM
Brad@RevXtremeAutoSports's Avatar
Thanks, Greg
No ignorance Bro, we all learn.
When you are removing the shocks, you will see a blue connector where the wire is running from the old shock. Discconnect it from under the car and remove the shock as you normally would. As close to the shcok as possible, cut the wire from the shock.
Use small wire cutters to strip back the cover to reveal a black and white wire. Strip back the covers on the two wires to bare. Take your resistor and solder it in between the black and white wire. Tape it off real good to prevent leaks. Go back under the car and reconnect it to the blue connector. Repeat this procedure at all four shocks and your good to go.
I have a video showing how to do this. for some reason my server is a little slow, but if you go to Itunes you can downlaod it there and follow along for the directions.
Good luck and let me know if you need any assisitance.
Brad
Old Mar 24, 2007 | 04:58 PM
I'm about 99 percent sure that if you dont have the three selector switch then you dont have the ride control. One other way to be sure is to look at your shocks and see if you have a wire running from them to a blue connector under the car. No wire=no ride control.
Good Luck
Brad
Old Mar 25, 2007 | 02:10 AM
LLVETTE's Avatar
LLVETTE
Brad
Thanks, I'm getting the shocks in a few days and I'll take a look at it. I'll get back to you if I have any questions...
Old Mar 25, 2007 | 05:28 AM
str8upchevy's Avatar
str8upchevy
From: 90% of all Fords are still on the road.....the other 10% actually made it home!
Brad
If only I had seen this a few weeks ago I wouldn't have spent $169 + S&H on the stupid simulators from Corvette Garage.
I wonder if they would take them back if I tell 'em I don't need them anymore??? PHSH...... I guess the only way to find out is to call them. (DUH)
Oh well, I guess if they don't I'll go ahead and use them since they're paid for and they're already here. (Still would've been nice to have that extra $159. for something else)
Old Mar 25, 2007 | 11:02 AM
Try putting them on ebay, you never know. Good luck
Old Mar 25, 2007 | 11:05 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
http://forums.corvetteforum.com/show....php?t=1658546
Great price for replacements
Old Mar 28, 2007 | 12:06 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
I actually have a set of (Brand New) Bilstein Sport shocks I'll sell you for $250 + S&H. ..
I'll take them..PM sent
and now back to your reg scheduled program...
