Jacking Pucks ?
Old Mar 22, 2007 | 03:00 PM
brzman's Avatar
brzman
Default Jacking Pucks ?
well in my case i have a 1999 FRC without a jack.
can i order a puck to put in a hydralic jack that'll
fit that small spot in the frame.
what do the rest of you use /
thanks
Old Mar 22, 2007 | 03:10 PM
hotwheels57's Avatar
hotwheels57
http://forums.corvetteforum.com/show....php?t=1644036
Old Mar 22, 2007 | 03:34 PM
brzman's Avatar
brzman
HOTWHEELS....FOR REAL !
get these through a BMW part catalog ?
one size fits all C5's ?
do they snap in and out or once snapped in
there in permanently ?
thanks Hot
Old Mar 22, 2007 | 03:43 PM
hotwheels57
Yes, to all the questions...get the round pucks though. The square ones are available, but they may cause problems later if you decide to install after market metal or composite rocker protectors. There are after market sources (site vendors) that sell an aluminum combination puck/rocker protector. You should check out ELITE ENGINEERING for those. I like the simplicity of these composite BMW pucks for my Z16.
You can order the pucks through the BMW source from that discussion or any friendly BMW dealership. They should be about $6.95 each and you'll want four. Some unscrupulous EBAY sellers have them for over $50.00 (4).
Snap them in and they're always there unless you strike something to dislodge them.
Old Mar 22, 2007 | 03:50 PM
HummelS's Avatar
HummelS
Ten bucks in materials, & 1/2 hour labor:
Old Mar 22, 2007 | 03:51 PM
threewinmag's Avatar
threewinmag
go cheap and buy regular hockey pucks and use screw-in eye hooks from the hardware store. it does the same job. by the way, you don't need four----two at best.
Old Mar 22, 2007 | 03:58 PM
HummelS's Avatar
HummelS
If you ever need to put the car on a lift that uses the adjustable arms, you'll need four.
Old Mar 22, 2007 | 04:15 PM
brzman's Avatar
brzman
thanks for the input guys...i need to make a call for these thingys
Old Mar 22, 2007 | 04:19 PM
04cad's Avatar
04cad
St. Jude Donor '07-'08
Default BMW pucks
I got the BMW pucks, they were inexpensive, fit perfect, arrived fast and you have the option to leave them in permanently or take them back out if you like.
Old Mar 22, 2007 | 09:01 PM
RonJ's Avatar
RonJ
I went the hockey puck and screw eye route on mine. Just the thing to use with a four arm hoist!!
RonJ ...
Old Mar 22, 2007 | 09:52 PM
OLD-GUY's Avatar
OLD-GUY
From: *MIDDLETOWN NY* "I thought I was an OLD-GUY, till I met Charlie"
hockey pucks
Old Mar 22, 2007 | 11:27 PM
dndrsn's Avatar
dndrsn
I use my "Magic Self Aligning Jack Board".
Old Mar 23, 2007 | 08:31 AM
moserbe's Avatar
moserbe
I use the aluminum pucks.
Old Mar 23, 2007 | 10:45 AM
threewinmag
True, but most of us DIYers don't have a four arm lift. I only take my car to one person that uses a four arm lift and they have their own pucks.
Old Mar 23, 2007 | 01:37 PM
HummelS's Avatar
HummelS
Not being argumentative, but I carry mine with me - circumstances like a flat tire may dictate where I need to have the car lifted, and if they have a four-arm lift, and no pucks, I'm covered.
Old Mar 23, 2007 | 02:37 PM
LTVetteVert00's Avatar
LTVetteVert00
I liked this idea...so, I ordered mine today. Now all I need is a lw profile jack...working on that too.
LT
Old Mar 23, 2007 | 03:31 PM
brzman's Avatar
brzman
now i like that "magic lifting board" c'mon give me more
To Jacking Pucks ?
Old Mar 23, 2007 | 04:01 PM
sandra1956's Avatar
sandra1956
Old Mar 23, 2007 | 04:04 PM
HawnHog's Avatar
HawnHog
Yeah! What's with the round thingie in the center of the board?
Old Mar 23, 2007 | 04:48 PM
dndrsn's Avatar
dndrsn
The round thingie goes down into the jack pad, keeps the board centered and prevents it from sliding off the jack when positioning under the car. The little clips on each side center it on the crossmember and keep it centered front to back. Making your life less complicated it's "dndrsn-ized".
