Oil change
Old Mar 24, 2007 | 12:45 PM
bassspring's Avatar
bassspring
Default Oil change
I have 70000 miles on my 2000 vert should I be using a oil addative if so what brand, I use Moble-1 oil. I have a small spot of oil after car has set about a week. Bassspring.
Old Mar 24, 2007 | 01:01 PM
GrayC5's Avatar
GrayC5
A quality synthetic motor oil meeting GM Standard GM4718M is all that you need. In fact both the owner's manual and GM Service Manual advise against using any oil additive. The following is from the 2003 owner's manual but yours should read much the same:
What Kind of Engine Oil to Use
Look for two things:
  • GM4718M
    Your vehicle’s engine requires a special oil meeting GM Standard GM4718M. Oils meeting this standard may be identified as synthetic. However, not all synthetic oils will meet this GM standard. You should look for and use only an oil that meets GM Standard GM4718M.
    Notice: If you use oils that don’t have the GM4718M Standard designation, you can cause engine damage not covered by your warranty.
  • SAE 5W-30
    As shown in the viscosity chart, SAE 5W-30 is best for your vehicle. However, you can use SAE 10W-30 if it’s going to be 0°F (-18°C) or above. These numbers on an oil container show its viscosity, or thickness. Do not use other viscosity oils such as SAE 20W-50.
Oils meeting these requirements should also have the starburst symbol on the container. This symbol indicates that the oil has been certified by the American Petroleum Institute (API). You should look for this on the oil container, and use only those oils that are identified as meeting GM Standard 4718M and have the starburst symbol on the front of the oil container. Your vehicle’s engine is filled at the factory with a Mobile 1® synthetic oil. which meets all requirements for your vehicle.
Substitute Engine Oil: When adding oil to maintain engine oil level, oil meeting GM Standard GM4718M may not be available. You can add substitute oil designated SAE 5W-30 with the starburst symbol at all temperatures. If temperatures are above 0°F (-18°C), you may substitute SAE 10W-30 with the starburst symbol. Substitute oil not meeting GM Standard GM4718M should not be used for an oil change.
Engine Oil Additives
Don't add anything to your oil. The recommended oils with the starburst symbol are all you will need for good performance and engine protection.
Old Mar 24, 2007 | 02:02 PM
c5_alive's Avatar
c5_alive
St. Jude Donor '08
Old Mar 24, 2007 | 02:37 PM
VinnyT's Avatar
VinnyT
Mobil 1.
5W-30 for winter
10W-30 for summer
Old Mar 24, 2007 | 02:39 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
I have always used Mobil 1 5W-30 in my car
Old Mar 29, 2007 | 10:42 AM
beav626's Avatar
beav626
A strong shop in the OKC area is offering a synthetic oil change for 37.00. I believe the oil is Kendall. I will check the specs and see if htis will work..
Old Mar 29, 2007 | 11:27 AM
steve8's Avatar
steve8
Mobil 1 should be all you need.
Old Mar 29, 2007 | 11:34 AM
csexton's Avatar
csexton
Chuck
Old Mar 29, 2007 | 01:50 PM
WetteVette's Avatar
WetteVette
Default Leaking Oil
Sounds like you need a new engine
Old Mar 29, 2007 | 02:03 PM
M6 Vetter's Avatar
M6 Vetter
Old Mar 29, 2007 | 02:06 PM
Patman's Avatar
Patman
Don't waste your money on additives, just pick a good synthetic oil that meets GM 4718M and change it when your oil life monitor tells you, and your engine will last a very long time.
Old Mar 29, 2007 | 02:27 PM
Ishams00vette's Avatar
Ishams00vette
I will have to agree with him!!
To Oil change
