Bolted the lift down
Old Mar 24, 2007 | 09:15 PM
Mike Mercury's Avatar
Mike Mercury
I wish I had a lift to bolt down...
Old Mar 24, 2007 | 10:20 PM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
That's great!
I can't wait until Tuesday
My best buddy is getting his SPX7 installed
Maybe I can get a ride on it
Old Mar 24, 2007 | 10:28 PM
DsC5's Avatar
DsC5
Ed. I'm so jealous.
Old Mar 24, 2007 | 11:03 PM
oaks99's Avatar
oaks99
nice job ed i thought i'd leave mine unbolted , but i too decided that it was time to nail it , once i had it where i wanted it i never moved it , so the bolts went in and it so much better , and i don't ever plan on moving .
oak
Old Mar 24, 2007 | 11:13 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Old Mar 24, 2007 | 11:51 PM
tellefan's Avatar
tellefan
Originally Posted by hotwheels57
It looks good. You don't need the caster kit now. Someone might need those for their BEND PAK (140# shipping weight). The only drawback that I'd foresee is if you want to move the lift (moving from home, outside for pressure spray, etc). You can get more lift with the casters (to clear the studs) if you place a 2x4 on top of the point where it connects with the crossbars.
Now that it's bolted down, you can remove the bolts from the passenger side runway and adjust them to any width you want since no cables or hydraulics run on that side.
After I made that post, I thought about using 2x4's just the way you said to do it. LOL Great minds think alike. David
Old Mar 25, 2007 | 12:02 AM
wamara's Avatar
wamara
Cruise-In II Veteran
Hi Patches,
Very clean work - looks great. I have a question:
Did you need to actually bolt the lift's legs down, as opposed to simply drilling the holes, maybe epoxying in a metal sleeve, and simply using hex bolts as pins? Isn't the big concern just a leg shifting laterally if things get cattywampus? With a pin 4"+ deep they couldn't move laterally, and you could then simply pull them if you wanted to move the lift, use the casters, etc.
I'll grant you this wouldn't be AS secure as bolting it down, but wouldn't it suffice? Or am I missing something?
Old Mar 25, 2007 | 08:28 AM
rws.1's Avatar
rws.1
nice job.
Old Mar 25, 2007 | 04:38 PM
rgtkst's Avatar
rgtkst
Originally Posted by Patches
Ceiling is only 10 ft. high. I park my dd Mustang under the vette. I could store the vette another notch higher even for a taller car underneath.
You support all three of our car companies
very cool
looks great !!! i sure want to do this. someday soon i hope too
