another engine code
Old Mar 25, 2007 | 11:59 AM
kacfiz's Avatar
kacfiz
Default another engine code
My check engine light came on again yesterday. The engine runs fine so I reset it once but it came back on. The code is p0200, Injector control circut. I don't even know what that is. Can anybody help???
Old Mar 25, 2007 | 02:22 PM
dpd's Avatar
dpd
open the hood and look at the left rear side of the engine where the harness comes around and goes over the bracket.the harness has probably rubbed through on the bracket.open i up and look carefully,you will probably see a couple of the wireshave rubbed and grounded out on the bracket.repair the wires and relocate the harness off the bracket.you should be good to go.
