Jacking locations
Old Mar 25, 2007 | 12:01 PM
Bobby Dee's Avatar
Bobby Dee
Default Jacking locations
Need some more advice here. This being my first Vette (finally), I don't want to make any mistakes here. It's a '97 coupe. I need to remove my front bumper facia for repaint because of some minor scratches on it when I got the car. What is the best/proper way to raise the car from the front and set it on jack stands? I know I can raise it from the side, but I don't have any "jacking pads" yet.
Bob
Old Mar 25, 2007 | 02:09 PM
DeeGee's Avatar
DeeGee
Here are the jacking points
This cars pretty strong. the old problems with flexing on the C4 really are not an issue
Old Mar 25, 2007 | 02:35 PM
photoguy's Avatar
photoguy
Great info! Thanks.
Old Mar 25, 2007 | 02:42 PM
rico750sxi's Avatar
rico750sxi
You can use a couple blocks of 2x4 if you don't have pucks. Or run to a Sports Store(Dick's, Sports Authority, etc.) and get a couple of hockey pucks.
Old Mar 25, 2007 | 04:02 PM
Bobby Dee's Avatar
Bobby Dee
DeeGee.......Thank you very much!!! Awesome info. I knew I could count on the Forum Folks!!!!
Bob
Old Mar 25, 2007 | 04:04 PM
Bobby Dee's Avatar
Bobby Dee
Rico....thanks to you also!! good stuff to know..Thanks!
Bob
Old Mar 25, 2007 | 04:27 PM
Patches's Avatar
Patches
You could also drive it up on a set of ramps. That's the easiest and safer than jack stands IMHO.
Old Mar 25, 2007 | 04:43 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Old Mar 25, 2007 | 04:45 PM
Optimus_C5's Avatar
Optimus_C5
From: If opportunity doesn't knock, build a door. South West Florida / Livin' The Dream
St. Jude Donor '12
Here's how I lift mine.
http://www.z06vette.com/diy_lift.php
Which ever way you lift your car make sure you do it safely!
Old Mar 25, 2007 | 06:25 PM
oldschoolvette's Avatar
oldschoolvette
Old Mar 25, 2007 | 08:00 PM
shannanl's Avatar
shannanl
I use the front and rear crossmembers. The are perfectly acceptable as jacking points. Just make sure you put something between the crossmember and the jack. I use a couple pieces of inch thick hardwood. My jack is not one of those ultra low profile, so I have a couple of 12" x 12" garden stepping stones that are about 1 inch high. I run the front wheels up on those and it gives me enough clearance to use the jack and boards. I bought 4 jack stands from Sears and the jack for less than $100.00.
Oh, as an extra level of safety, I leave the jack engaged on the end I am working on, along with the jack stands and then I place a couple of concrete blocks under the frame just in case #1 and #2 fail. I am sure the odds are about 1 in a gazillion but the idea of 3,000+ lbs. falling on me is not in my future plans.
Old Mar 25, 2007 | 08:18 PM
Bobby Dee's Avatar
Bobby Dee
Thanks to everyone!!! The knowledge, information, how-to's, and support in this forum is outstanding!!! I love it here!
Bob
Old Mar 25, 2007 | 09:04 PM
redrider's Avatar
redrider
Thanks to some good advice here on the forum, I purchased a set of lifting pucks from Elite Engineering. Excellent quality, although the home made version (hockey pucks) would probably work just as well.
Also made a couple ramps from 2x10 lumber to get the car up just enough to get the jack under. Works like a charm.
Be safe and be careful.
Old Mar 25, 2007 | 09:08 PM
moserbe's Avatar
moserbe
To Jacking locations
