Trans, Diff. Oil change interval?
Old Mar 26, 2007 | 09:39 AM
tommybilt's Avatar
tommybilt
Default Trans, Diff. Oil change interval?
What is the interval for a fluid change in these cars?
Old Mar 26, 2007 | 10:03 AM
pylant's Avatar
pylant
There is no set change period for the diff.
Sort of like brake fluid but I would not go the life of a car without changing these simple fluids.
It is subjective but I would say every 30,000 miles is reasonable. Same for brake fluid, antifreeze and ATF.
But hey if you want never change it, nothing says you have to.
Old Mar 26, 2007 | 10:07 AM
rws.1's Avatar
rws.1
These products can go 100,000 miles under normal driving conditions, but I would personally never do that...
I change mine out every other year....
Old Mar 26, 2007 | 10:13 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Every year here.
Old Mar 26, 2007 | 11:18 AM
HollywoodFRC's Avatar
HollywoodFRC
Default "Grease is Cheaper than Steel"
I changed all fluids when I bought my FRC. I plan to change all fluids (Oil every 5,000 miles) every two years or 24,000 miles just to see what's going on. I have magnetic plugs in the oil pan, transmission, and differential. Next time I change, I'll see any metal if there's issues. Just changed my oil and the magnetic plug was clean, no metal. Whew! My C5 FRC was used so I didn't know what I'd find. Just a suggestion. IMHO you need to establish a fluid baseline, especially if you bought a used C5.
To Trans, Diff. Oil change interval?
