C5 Overheating!
Old Mar 27, 2007 | 10:08 PM
vettesmith02's Avatar
vettesmith02
All good advice. The biggest culprit is the crap up in the radiator.
This is the first vehicle I've ever had that deposits bugs on the garage floor regularly.
They fall from the very top of the ac cooling coils as the engine cools down.
You think the spiders would go up there when I get home and have a hot meal.
Old Mar 27, 2007 | 10:31 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Just a note - there is a debris screen that will eliminate this issue - stull in the rad front (21st Century MC 972 417 7177)
Our C5's should have a HOOVER sign on the front undercarriage where the rad is located
Old Mar 27, 2007 | 11:50 PM
z06Bigbird's Avatar
z06Bigbird
You making me hungry!!
Old Mar 28, 2007 | 12:04 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Originally Posted by AC54ME
Some adjustment (I.e., cooler thermo, program the fans to come on 'earlier') are possible remedies.
how can i re-program the fans to come on earlier?
Old Mar 28, 2007 | 09:57 AM
LTVetteVert00's Avatar
LTVetteVert00
Originally Posted by tin
Just go to Advance auto and buy a bottle of water wetter and pour
it in the radiator ,you will run around 15 to 20 deg cooler.
safe for your car ,i used it in my and its all good now.
Wait a minute...what about only using DexCool??
Old Mar 28, 2007 | 12:08 PM
FASST LN's Avatar
FASST LN
You should also check your fluid levels (WHEN COOL) at the radiator. For some reason if your radiator is quite low and you only add water/coolant to the resovoir, it doesn't seem to make it into the radiator. I know this goes against the entire point of the resevoir design, but that has been my experience.
In short, try adding some distilled water directly into the radiator and also check for the debris like everyone else mentioned.
Old Mar 28, 2007 | 12:28 PM
oldschoolvette's Avatar
oldschoolvette
Originally Posted by kevin40zx
Are you sure it's overheating? Up to 230 deg. is considered normal operating temp. when sitting in traffic.
Old Mar 28, 2007 | 12:33 PM
tikiman's Avatar
tikiman
If adding fluid to the reservoir tank does not get it into the radiator, how does one refill the entire thing after a flush?
