lug nut torque setting
Old Mar 28, 2007 | 06:56 PM
big dad's Avatar
big dad
Default lug nut torque setting
how tight should the lug nuts be on stock polished wheels be
thanks in advance
Old Mar 28, 2007 | 07:03 PM
Blue Smooth's Avatar
Blue Smooth
100 lbs
Old Mar 28, 2007 | 07:31 PM
steve8's Avatar
steve8
100 it is.
Old Mar 28, 2007 | 07:33 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Originally Posted by Blue Smooth
100 lbs
Old Mar 28, 2007 | 07:40 PM
DAVS Y2K's Avatar
DAVS Y2K
Banned Scam/Spammer
Nobody's said this yet but it is 100 ft/lbs.
Old Mar 28, 2007 | 07:53 PM
blkchipC5's Avatar
blkchipC5
Old Mar 28, 2007 | 07:54 PM
tommybilt's Avatar
tommybilt
Dont forget to torque in a star pattern.
Old Mar 28, 2007 | 08:12 PM
Oldvetter's Avatar
Oldvetter
Technically it is 100 ft-lbs. Also re-torque them after a day or so of driving.
Old Mar 28, 2007 | 10:13 PM
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
What technique is that???
Old Mar 28, 2007 | 10:21 PM
silverbullit99's Avatar
silverbullit99
It's the ,,,I'm not sure if they are tight enough technique ...
Old Mar 28, 2007 | 11:04 PM
94legaleagle's Avatar
94legaleagle
OR, the "lug nuts on aluminum rims tend to get loose after a while" safety check
Old Mar 29, 2007 | 12:15 AM
Mpwr's Avatar
Mpwr
80lbs if you put them on lubed other wise 100 lbs dry
Old Mar 29, 2007 | 07:55 AM
100 ft lbs is what I torque mine down to.
Old Mar 29, 2007 | 08:05 AM
vetdude's Avatar
vetdude
Tip: If the torque wrench doesn't click when set to 100 ft. lbs, do NOT assume the lug nut is torqued to 100 - it could be over-torqued. Back it off and re-torque to 100 to be sure. Unequally torqued lug nuts is one of the primary causes of brake rotor warp.
Old Mar 29, 2007 | 08:28 AM
photoguy's Avatar
photoguy
Did somebody say 100 yet???
Old Mar 29, 2007 | 08:29 AM
oldschoolvette's Avatar
oldschoolvette
Old Mar 29, 2007 | 08:39 AM
slick500's Avatar
slick500
well i guess im a little diff, i do 75 in a star and then 100 in a star, but yes 100 is it
To lug nut torque setting
Old Mar 29, 2007 | 08:45 AM
bkemp's Avatar
bkemp
100 ft.-lbs
Old Mar 29, 2007 | 11:59 AM
SavPrato's Avatar
SavPrato
Anybody have a problem with shearing the stud when torquing at 100 ft-lbs? I've done this vary carefully many times in the past but I've managed to shear a stud last year. Calibration problem maybe?
Old Mar 30, 2007 | 04:10 AM
SLPRC5's Avatar
SLPRC5
