picked up my car from the dealer body shop yesterday after it was hit in the drivers door. Only damage looked to be a hole in the door. After trying to repair the hole they decided to order a whole new door skin from GM.
1st skin was peeling apart when it was delivered. second skin looked great. I found some major impoerfections in the paint but the big problem is the door does not sit flush with Qtr panel like on the passanger side. It is something only a corvette owner would see but I will not accept it like that.
The idiot of a repair guy came out and said that he could not change the shape of the door that is the way it is. he tried to adjust the striker but that brought the bottom of the door in too.
Short story is they ordered a new door and will try again next week.
I would check the adjustments on the striker again.
When we moved the stricker in the top of the door sucked in like it was supposed to.
But the bottom looked as if it was pushed in.
Not to mention the verticle space where the door meets the Qtr panel is larger on the repaired door. The Passanger door looks perfect.
I have my doubts about the workmanship of this shop as they called me last week to say they cant fix my window. They cant make it drop when you open the door and raise when you shut the door...
I said that I own a C-5 not a C-6...
come to think of it maybe they ordered a skin to a C-6...
I have put a few door skins on in the past but not on a Corvette. One thing is for sure, if it is not a perfect fit when you glue it on it will not be any differenct when painted. New door should solve it now but even that requires fitting. Keep posting...............
Took my her back to the shop today for them to repair the door here is the list of things I needed done...
Corvette Issues 4-9-07
Driver Door
Does not fit like passenger door
Does not seal at window (Lets wind in on highway)
Paint on Driver door got gnats in it while it was being sprayed (Black specs all over Door)
Inside Door Pull doesn’t sit properly
Insides door pull bezel looks beat up / broken
Inside door panel sounds squishy when pressure is applied
Door rattles when driving
Door rattles very bad when shut with window down (Doesn’t sound factory) Interior
Extremely Dirty from Shop Dust. (All over, dash, cargo area, seats, crevasses, etc… Needs to be detailed)
Drivers Seat lumbar does not work (Makes sound but nothing inflates)
Drivers Seat now rocks like extreme pressure was put in it
Exterior
Overspray all over car including all windows and Glass top
Hood look like primer got sprayed all over it (Looks like it needs to be repainted)
Trunk-lid and Driver Qtr Panel has been burned by buffer (needs to be repainted)
Passenger Rear Wheel has primer sprayed all over it (Maybe all wheels)
Paint looks dirty on Passenger Qtr Panel repair
Passenger Door has lines that were missed while cleaning up the car Mechanical
Car was having trouble starting after I got it out from the shop. I put in new Battery but it did not help (Starter / Alternator)
The Body shop has new management since I was last there last week. We will see what happens.
Driver Door
Exterior
Sorry to hear about all the issues. With that list of defects, I would be worried about even letting them try and correct them all. Good luck with the repairs and I hope they get it done to your satisfaction.
