Trans Leak
Old Mar 29, 2007 | 06:31 PM
omarcoolguy's Avatar
omarcoolguy
Default delete
delete
Old Mar 29, 2007 | 08:27 PM
omarcoolguy
Originally Posted by VetteTech81
where is is leaking from? I assume it's and Auto?
-=Rick
it wasnt leaking the was some seepage around the pan and a fewdrops on the floor....i think it needs a gasket
Old Mar 29, 2007 | 10:51 PM
kingsey's Avatar
kingsey
Damn dude more problems maybe its just a seal
Old Mar 29, 2007 | 11:25 PM
Hope it is not too serious.
Old Mar 30, 2007 | 08:38 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
I had the same problem. Kept checking the fluid and was concerned about replacing it. Learned that there is a seal that seats differently when the weather is cold and will reseal in warmer weather. I'll see if I can find the post and forward it to you. It mentions the material the seal is made out of. The response from a Chevy Tech who rebulds them.
I cleaned any and all fluid off the undercarriage and sure enough, warmer weather, more driving, no leaks. The level is the same. There is also a vent that sprays some out if it is over filled.
I am putting on a cooler so I'll check the level again.
Old Mar 30, 2007 | 11:07 AM
omarcoolguy
thanx its good to here good news......i hope thats true....and thats whats happenng to mine....i wont know till next week when i start her up
Old Mar 30, 2007 | 01:55 PM
omarcoolguy
any other sugg?
Old Apr 2, 2007 | 02:13 PM
waunavet's Avatar
waunavet
St. Jude Donor '20
My '99 coupe, A4 w/30K does the same thing. Over the winter, I'll get 4-5 drops on the floor from the front of the trans. When driven, it's greatly reduced but not eliminated. I always have a little oil around the vent. I'm guessing it's a rear main seal issue.
To Trans Leak
