manual tranny issue
Old Mar 29, 2007 | 09:34 PM
hk940's Avatar
hk940
Default manual tranny issue
it's more of a question but i have a C5 and it's running great!
the only problem is a little tranny issue that only comes up sometimes.
i have a B&M shifter in it and it seems that it won't "go" into first. it shifts easily into all gears most of the time. but sliding it into first at a red light after "coasting in" with the clutch in. or sometimes just shifting it into first can be an "issue" i can shove or force it in (clutch is in of course) but more than not it shifts smooth into first. it also "clicks" loudly into the first three gears.
it's kind of a pain.
any idea what the problem is?
i adjusted the shifter arm "rotator cup thingy" (sorry i don't know what you call it) but it's part of the car that is the socket the shifter goes into and not the shifter ball. anyway that is in the middle of it's travel and does not seem to be binding.
thanks,
hk.
Old Mar 29, 2007 | 09:47 PM
oaks99's Avatar
oaks99
i would guess that is where your problem lies , i know a buddy of mine put in a c6z06 shifter and had problems getting it adjusted
oak
Old Mar 29, 2007 | 10:16 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
oak
That buddy of Oak's who had the problems would be me
Try adjusting your shifter base. It will take sometime but you will get it
Old Apr 9, 2007 | 11:19 PM
Matt Evans's Avatar
Matt Evans
Try the procedure listed near the end of this link.http://forums.corvetteforum.com/show...post1559329626
Old Apr 11, 2007 | 06:36 AM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
This is a common problem with C5 Zs, try putting her in reverse while stopped and from there she may slip easily into First gear!
Old Apr 11, 2007 | 10:10 AM
87SAM's Avatar
87SAM
I know if I get lazy and don't quite shove it all the way into first from a stop, it would like to take my wrist off when it pops out.
Old Apr 11, 2007 | 12:45 PM
VetteBandit's Avatar
VetteBandit
This is fairly common - at least I think I know what you are describing. Next time this happens try and shift into 2nd, 3rd, or whatever and then go back to 1st. I would bet your problem would be solved. I believe the route is just a small syncho/gear mismatch from when you shift out of a higher gear and then back to 1st.
Hope that makes sense.
To manual tranny issue
